  • Guests: 36
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
whats the wattage for these resistors?
pauleddy
Sun Oct 10 2010, 08:28PM Print
pauleddy Registered Member #2909 Joined: Wed Jun 09 2010, 12:31AM
does any one know what the wattage for these resistors and know of any good uses for them.
the big one is 4ohms
and the smaller one is 10ohms
Junk2024
Sun Oct 10 2010, 08:55PM
I can only guess comparing it to some that I have on hand. The smaller one looks like it is close to 50w. The bigger one is over 100W. It might be 250W.
Duality
Sun Oct 10 2010, 09:11PM
Duality Registered Member #1951 Joined: Sun Feb 01 2009, 01:59PM
the bigger one looks a bit heat sinked? lol
Shrad
Sun Oct 10 2010, 09:25PM
the smaller one is 5 to 10 watts (I have a bunch of similar resistors each rated between 1 and 10 watts)
the bigger looks like it is either heatsinked or the resistive wire itself serves as heatsinking... looks like it is more than 100W definitely
pauleddy
Sun Oct 10 2010, 09:27PM
the big one is a resitive wire as stated was measured it a 4ohms
therf both from large dc power supplys, smaller on is from a 12v 50A supply and th big one is from a 30V-50V, 300A-600A supply i aslo got a 140000uf 50V cap from the large supply
radiotech
Sun Oct 10 2010, 10:28PM
200 watts for the big one. Can do about 8 amps.... Nice load for a car amp. You find those in old wound rotor motor starters, especially on cranes.
pauleddy
Sun Oct 10 2010, 11:40PM
hmm.. well ther was about 4 of them and it was in a big yellow stell box that had a 250ac line in and meter for 50vdc and 500Adc
teravolt
Mon Oct 11 2010, 02:09AM
the big one is 225W and the little one should be 50W. The big one is less than a ohm
pauleddy
Mon Oct 11 2010, 06:31AM
hmm my ohm meter says that its closer to 4ohms
radiotech
Mon Oct 11 2010, 06:11PM
Dont run the big one so the element glows!
It is made by winding that sidewise strip
on a poreclean tube and then dipping
it in a ceramic glaze and baked.
The resistor will end up loose.
Did you get all 4 of them out of the
box and the ammeter too? How about
the mounting hardware?
I'd have snatched the whole box.
