  • Guests: 29
High voltage ozone generation
dannybeckett
Sun Oct 10 2010, 12:00AM Print
dannybeckett Registered Member #3300 Joined: Sat Oct 09 2010, 11:57PM
Hi guys, I am trying to make an ozone generator. I have a ZVS driven flyback going to a glass with tinfoil around the inside and outside. there is no hiss or corona discharge or anything. The voltage is at least 8kv. Do I need to ground one side of the flyback to get corona?
dannybeckett
Sun Oct 10 2010, 12:09AM
ok i have discovered something strange. when i move the electrode thats attached to the foil thats on the outside of the glass away, it arcs to this foil as if the glass wasnt even there! how can the outside and inside foil be making contact? is it acting as a capacitor??
Duality
Duality Registered Member #1951 Joined: Sun Feb 01 2009, 01:59PM
dannybeckett wrote ...
normally not, but i could be wrong :)
dannybeckett
Sun Oct 10 2010, 12:15AM
more experimentation - I took the outside foil off and arc'd to the glass using a wire - small arcs and corona and ozone which is what i wanted. this thing must be acting as a capacitor lol! I guess i have to use wire mesh instead?
dannybeckett
Sun Oct 10 2010, 12:19AM
hmm, just tested it with a function gen and oscilloscope - 1mhz passed parallel into the 'capacitor' and no attenuation seen - im so confused now
ubuntupokemoninc
Sun Oct 10 2010, 12:22AM
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
how about jm's 100kv flyback driver, that creates lots of corona:-D
Sun Oct 10 2010, 02:42PM
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
if you heat up glass, it becomes conductive.
PAul:-D
Adam Munich
Sun Oct 10 2010, 04:36PM
Yes it does, but you need to get it quite hot. From what I understand you have 2 pieces of foil separated by a piece of glass. That is a capacitor and at HVAC it will be conductive. Typically when I need ozone I use to pieces of aluminum mesh separated by a 3/32" lexan sheet. I then full wave rectify the power source.
dannybeckett
Sun Oct 10 2010, 04:40PM
Why would this capacitor only attenuate high voltage 20KHz signals, yet not attenuate a low voltage 20KHz signal? I also coiled a wire around the glass and the same thing happened. I do have a working system now though :-
1286728795 3300 FT98268 Dsc00137
(p.s cheers for the input)
Adam Munich
Sun Oct 10 2010, 06:10PM
I don't think the capacitor was to blame. I pin the fault on corona, and looking at your picture there is tons of it. With a low voltage signal corona doesn't happen and it passes right through the cap unharmed. When you crank up the volts however, a lot of power is lost as corona and the signal tends to be weak and filled with noise.
