  • Guests: 55
looking to buy a mazelli flyback driver
Microwatt
Wed Oct 06 2010, 05:30PM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
I am working on a research project and I don't have the patience to make my own pcbs does anybody here have a good robust design that will output up 100 watts. I am looking to drive a CCW voltage multiplier to 100kv.a kit would also be fine.
Adam Munich
Wed Oct 06 2010, 10:30PM
Microwatt
Thu Oct 07 2010, 04:51AM
I saw that but it seems that nobody is selling.
Thu Oct 07 2010, 06:04AM
I have the 'type 1' compact boards, available for $5 + shipping as shown in the listing. Send a PM for details.
Matt Edwards
Fri Oct 08 2010, 12:49AM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Why not just make a board yourself? You can buy the supplies to print a cheap board at radioshack. Or you can just use a breadboard and connect with jumpers or heavy solder traces. Making the board is part of the fun...
GrimX9
Fri Oct 08 2010, 02:07AM
GrimX9 Registered Member #3225 Joined: Wed Sept 22 2010, 02:14AM
I just bolted the MOSFETS on and freeformed the circuit off of it. Haven't had a problem other than exploding caps because they aren't MKP type.
Microwatt
Fri Oct 08 2010, 02:52AM
becuase i want a professional looking circuit. this is for a project which will go in front of specialized PHd's.
Why isn;t there anybody on this board who sells drivers Why is it so hard to make drivers and sell them? I know you guys like building stuff. But the world has advanced considerably since 1971.
mnr
Fri Oct 08 2010, 03:36AM
mnr Registered Member #996 Joined: Sun Sept 09 2007, 06:17PM
Microwatt wrote ...
Because this forum is primarily for the sharing of knowledge between experimenters. "Why is it so hard to make drivers?" is a pretty good question though - it wouldn't cost you much to get a nice PCB made with soldermasking and silkscreening (at BatchPCB for example) and solder on the components yourself.
Fri Oct 08 2010, 05:17AM
Microwatt wrote ...
....Why is it so hard to make drivers and sell them? I know you guys like building stuff. But the world has advanced considerably since 1971.
Well first off, this forum is for those who build there own stuff, advise others, and collaborate. we generally dont freeload off each other, we each do our own work.
Second, I guess I could help you, if you cant find anyone else, but if time is an issue-I dont know, Ive got a programming test on monday, oct 11, maybe you can get your boards into a shop (like, Sunstone) in the next two weeks. If we start now.
When do you need all this by?
Anyway, are there rules for buying and selling for too few posts? Hold on, I need to check the rules.
EDIT: 15 posts for selling, none for potential buying. Ok, I guess... maybe I can help you then.
PS. im totally buzzed on pepperment schnaps right now.
Fri Oct 08 2010, 12:19PM
Microwatt wrote ...
Because there is no market for mass production ;)
