  • Guests: 71
4 mot stack questions
ubuntupokemoninc
Sat Oct 09 2010, 08:54PM Print
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
My dads friend said it would not be a good idea to put 4 mots in series , i was gonna put them oil, but he says they will still arc over,is there any risk of an arc over?
this is gonna be tc supply,and it will be ballasted
Adam Munich
Sat Oct 09 2010, 10:07PM
Let me ask, is this your first experience with tesla coils or resonant power circuits?
If so, I highly recommend you stay away from the quad MOT. Likely they will not flash over under oil, but they can supply a massive amount of power. One mistake and your dead.
Why not start with something smaller, like a neon sign transformer?
Coronafix
Sat Oct 09 2010, 10:51PM
They should be all right under oil, but they definately flashover if not under oil. They will run for a bit, but with the Rf and voltage involved in the tank circuit of a TC, they tend to catch fire.
ubuntupokemoninc
Sat Oct 09 2010, 11:58PM
this will be my 3rd tc
Duality
Sun Oct 10 2010, 12:05AM
Duality Registered Member #1951 Joined: Sun Feb 01 2009, 01:59PM
if you put em in oil, you wanna put em under a vacuum while in oil.
why you ask me?
its to suck those bubbles/air remaining in secondary and primary out, that can cause arc overs? (correct me if i am wrong).
any way it's to play it save smile
Coronafix wrote ...
could you explain how it can/could cause fire?
ubuntupokemoninc
Sun Oct 10 2010, 12:17AM
K I'll try the vacuum, could i try letting her soak for a week instead?
I hate nst and obits, the are gutless and expensive, my first coil used an obit and i obtain 3 inch steamer, plus it later died even with a safety gap, i repaired the transformer, it is now in oil,(the black epoxy resin is worth less)
Adam Munich
Sun Oct 10 2010, 01:35AM
Letting it soak won't do anything to get those tiny bubbles out. Though I have managed to oil a few x-ray transformers only by massaging the windings for 30 minutes to squeeze out air, that wouldn't be possible with an MOT.
You *might* be able to avoid a vacuum by vibrating it for a few days, though I'm not 100% sure that would work. Your best bet is still a vacuum. If you don't have a "real" vacuum pump, do as I do and put 2 refrigerator compressors in series. A mini fridge one followed by a regular one. It works fairly well.
ubuntupokemoninc
Sun Oct 10 2010, 02:02AM
got an air compresses with no tank, could i hook it up back wards?
maybe a really big shop-vac
Adam Munich
Sun Oct 10 2010, 02:12AM
Shop vac won't work, but the gas compressor may. Be prepared to lose it though. I use refrigerator compressors because you can get them for free/very cheap.
ubuntupokemoninc
Sun Oct 10 2010, 02:32AM
k, do i have to worry about getting freon every were
