  • Guests: 270
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
need a high high side driver
Thu Oct 07 2010, 08:37PM Print
If I want to drive a mosfet/igbt where the high voltage is 750v what are my options? All the high side drivers I see listed are only good to 600v. Can an optocoupler help with the solution?
Thu Oct 07 2010, 11:36PM
There are 1200V rated ones. Careful with opto's that arent meant to drive gates. remember turning a gate on/off reqiures a lot of sourced/sunk current in the nS range. you can also look for IXYS ones.
