  • Guests: 32
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
high voltage transformer without primary
Duality
Thu Oct 07 2010, 07:49PM Print
Duality Registered Member #1951 Joined: Sun Feb 01 2009, 01:59PM
sorry for this simple question, but what's a high voltage tranformer without a primary called?
i have seen some, if i know the name i can google on cheesey:)
Thu Oct 07 2010, 08:33PM
I would call that a high voltage choke. tongue
radiotech
Thu Oct 07 2010, 10:54PM
Try googling the concept of inductive stepup. An inductor of 1 henry with a current of 1 amp flowing through it will have a voltage drop of 6.28 million volts at 1 mHz.
Just hook it in series with 25.6 femtoFarads and feed the series combination with as few volts.
Thu Oct 07 2010, 11:04PM
radiotech wrote ...
.... voltage drop of 6.28 million volts at 1 mHz.
do you mean 1MHz, Mega- or Milli- ?
cedric
Fri Oct 08 2010, 11:40AM
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
an autotransformer? or a ballast use in starting mode ?
Fri Oct 08 2010, 11:44AM
In the case of a resonant voltage doubler, as per thyratron power supply, I would call it a charging choke.
radiotech
Fri Oct 08 2010, 09:38PM
Patrick wrote:" .... voltage drop of 6.28 million volts at 1 mHz.
Mega ie 1e6 Hz
Can you envision 6.28 million volts across 25.6 FemptoFarads ?
or 2* pi * Megavolts.
HazzWold 1993
Sun Oct 10 2010, 04:53AM
Could you call a magneto (Like from a lawnmower, or old engines) a Hv xformer without a primary? it only makes a high voltage spark for the ignition of the fuel but theres no primary, it just has a magnet run past it.
