  • Guests: 91
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
H-bridge can provide power from GDT, how?
Avi
Tue Oct 05 2010, 06:53PM Print
This is what happens when an unpowered bridge is connected to a load where the input power usually goes. only the GDT is driven. See youtube video description for circuit details.
the video (this will be removed once someone can explain it)
schematic
Tue Oct 05 2010, 06:56PM
Look at this thread :)
Avi
Tue Oct 05 2010, 07:30PM
was thinking something along those lines, but deriving an exact current path is proving difficult, even in simulation
ScotchTapeLord
Wed Oct 06 2010, 12:09AM
I've found some strange voltage differences in different parts of my H-bridges when poking around with a multimeter with power supply off and gate drive on. I'm guessing it's the same deal.
Wed Oct 06 2010, 09:11AM
Miller capacitance. Same reason a ZVS will run with only its gate power supply and the main power turned off.
CT2
Thu Oct 07 2010, 06:17AM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
I've noticed the same thing with my H-Bridge, powering a tesla coil. Where you had the inductor in your circuit I had the primary, and with the secondary in place it would light flourescent tubes. No power connected, only signal through GDT. It seems it transfers a decent amount of energy through.
