  • Guests: 42
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
transformer question for inverter
Tue Oct 05 2010, 02:41AM Print
I am hoping someone with a good understanding of transformer theory can explain this behavior.
Part of the stability of a good induction heater would be the ability for the unit to withstand losing the load. I use current limiting. However, I have noticed that when the turn count on the coupling transformer to the series resonant tank has about 17 or less turns, the current waveform unloaded has a lot of ringing at the inverter voltage transition. When I put the load in the current waveform is perfect and clean. If the coupling transformer has more turns AND I have the same current going through there is no ringing.
Does anyone know why this happens? Does it have anything to do with magnetization current? I know I am well below saturation by at least an order of magnitude.
