  • Guests: 29
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
My new multimeter is here.
Adam Munich
Tue Oct 05 2010, 02:28AM Print
I bought this true RMS multimeter for $79 last week, and I am very impressed to say the least. Before I get started, here is the unboxing. I'm sorry the first few photos are grainy, I forgot my camera was set to ISO400.
*Front of box*
*Back of box*
I was surprised to open the box and find this.
*Inside of the box*
*Inside of the inside of the box*
*Everything laid out nicely*
Batteries included! It came with probes, RS232 cable, CD, manual and a k-type thermocouple. The probes are very well built, all rubber and no plastic. They came with dust covers for each end as well. The thermocouple is an average thermocouple.
*Probe Pic*
According to the manual this meter is optoisolated from any computer. Well seeing how the RS232 cable only has a phototransistor on the butt end, I would say it definitely is. I haven't tested the software yet though.
Now the meter itself. It is well built, rubberized and has a huge backlit screen. Although it's not as light as I thought it would be weighing in at 407g, I'd still like it to have a few more ounces. My meter had a small scratch on the rubber at the bottom to the left of the lightning bolt symbol, but I don't feel that is important seeing as it's a tool likely to get scratched up anyway.
*Front*
*Back*
The meter takes 3 samples/sec, and reaches a stable reading within 2. I am going to test the accuracy tomorrow, so "stay tuned."
Tue Oct 05 2010, 03:44PM
Looks fine, and just goes to show you don't have to break the bank to get a useful and versatile instrument nowadays.
radiotech
Tue Oct 05 2010, 06:34PM
That instrument appears defenseless in a hostile environment just waiting to reach out and touch something. How will you prevent it, and the computer attached to it, from following your last meter into the dustbin?
Adam Munich
Tue Oct 05 2010, 07:35PM
It is completely optoisolated from the computer, (led and phototransistor). It would take quite a lot of volts to bridge that gap. As for the meter itself, all meters are defenseless; it's up to you to defend it from the hazards of electricity.
Also I tested the frequency function with a function generator today and was shocked at the accuracy. Here is the measured % error of the meter for different frequencies. And yes I did remember to divide by 100.
5MHz ---- .04%
500kHz -- .03%
50kHz --- .03%
5kHz ---- .05%
500Hz --- .5%
50Hz ---- 1.2%
5Hz ----- 4.8%
It starts to suffer at lower freqs. There was no difference in measurement when the waveform was changed; Sawtooth Sine Square and Triangle all measure the same. It started to lose count over 5.12MHz, which is OK since it's only rated for 5.
I'll measure the accuracy of the ohmmeter, capacimeter, and voltmeter some other time.
Nicko
Thu Oct 07 2010, 06:05AM
It'd be interesting to see how "true" the "trueRMS" feature is. Many (most!) such meters rely on the waveform being periodic and symmetric around 0V. Also, some assume the waveform is sinusoidal etc.
Even Flukes can have this problem - see Link2 . I believe my trusty Tek DMM916 handles this correctly, but I haven't looked for a while...
Can you do any tests to see if it handles a DC offset in the AC waveform correctly?
Cheers
Adam Munich
Thu Oct 07 2010, 06:19AM
I'll test it tomorrow, though I'm not sure if the function generator I'm borrowing has a DC offset function. I suppose I could put the generator in series with a battery to move the wave though. Since the freqmeter didn't care what kind of wave it was measuring, it might not require a sine for voltage measurement. I'll check that too. I'll also check the resistance measurements against a couple ±.05% resistors.
Anyone know of a good way to test the capacimeter?
Edit: Just read that page, I'll use the diode method too.
radiotech
Thu Oct 07 2010, 06:50AM
Check the capacimeter by seeing if it thinks diodes or resistors are capacitors.
Thu Oct 07 2010, 02:23PM
Nicko wrote ...
Nick: As far as I understand it, that IS the correct way. It's certainly how I expect a true RMS meter to work. OK, so it's not technically true RMS, but if it weren't like that, the AC ranges would be capable of measuring DC signals too, and that would be terribly confusing: you wouldn't know if the voltage you were seeing was AC or DC. (or both...)
I guess it's no fluke (ba-boom!) that it also makes the design of the true RMS circuit easier because you don't have to worry about DC offset.
thedatastream
Thu Oct 07 2010, 08:00PM
Nice meter :)
Some true RMS meters struggle with high "crest factors" e.g. a low duty cycle high pulse amplitude
The meters that use thermal sensing to calculate true rms aren't affected by this IIRC.
Thu Oct 07 2010, 09:54PM
Steve McConner wrote ...
Nicko wrote ...
I agree that "true RMS" means just that, e.g. effective voltage or current in heating a resistive load.
But - when the range selector says DC, we properly expect (and get) just the DC component of a mixed waveform.
Nick: to use the RMS feature, you move the range selector to an AC scale. Is it then a surprise to get just the AC component of a mixed waveform? As your reference states, if the same signal gives a nonzero result on DC scale, you can externally do an RMS addition of the two readings.
[edit] And Steve: if meter indicated the true RMS of DC+AC waveform, an external RMS subtraction of the DC reading would give the correct AC value.
To find out if a meter is AC-coupled on AC ranges, you don't need a function generator. Just a transformer and battery that can be connected in series. Or, uh, just a battery. smile
I believe the non-thermal implementations of true-RMS generally employ a precison analog RMS converter, closely related to an analog multiplier. The input is precision rectified, then squared and averaged. Feedback is used to generate a DC signal that develops the same output from an identical squarer circuit. There is no implicit requirement for periodicity or zero-average input. I bet that's much more efficient than high-rate analog to digital conversion and digital RMS computation. Either way, it's challenging to stay accurate at high frequency or when waveforms have a high crest factor.
