  • Guests: 53
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Voltage Doubler? Unsure??? Old CRT parts...
Matt Edwards
Mon Oct 04 2010, 02:05AM Print
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
I found this inside of a badly damaged 1968 GE Porta-color television model WHE5264WH. It has absolutely no markings on it. The backside (top) is black. Both the black and green wires are rated 20kv and the red wire is 40kv. I am assuming it is a voltage doubler but wanted a second opinion.
1286157954 2838 FT0 Doubler
Matt Edwards
Mon Oct 04 2010, 02:22AM
Oidium45 wrote ...
I found this inside of a badly damaged 1968 GE Porta-color television. It has absolutely no markings on it. The backside (top) is black. Both the black and green wires are rated 20kv and the red wire is 40kv. I am assuming it is a voltage doubler but wanted a second opinion.
I was also hoping that someone could give me a clue how to connect it if i wanted to use it on another circuit...
dmg
Mon Oct 04 2010, 03:01AM
Looks more like a multi stage half wave multipier, I had one ages ago.
the unforchunate thing with these multipliers, is that epoxy (or whatever material yours is), makes it rather hard to see the insides.
without a part number, or even knowing the condition of the unit, I cant possibly tell you how to wire it up, but perhaps someone else can.
Matt Edwards
Thu Oct 07 2010, 12:27AM
Thank you! After looking at it I believe that you are probably right!
