  • Guests: 48
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Capacitor mounting stud question
dmg
Fri Oct 01 2010, 10:32PM Print
I have this capacitor, and it has a mounting screw on the buttom, with a plastic nut, that goes around a 3/8" threaded rod.
I tried messuring between the terminals to see if there is any electrical contact between the stud and the terminals of the capacitor, but all ive gotten is false readings with no clear answer,
this capacitor still works and charges up, but I wonder if that stud is connected in any way to the terminals.
does anyone have capacitors like this one?
1285972347 2628 FT0 Semicap 001
1285972347 2628 FT0 Semicap 002
Fri Oct 01 2010, 10:50PM
The threaded mounting stud is connected to the negative pole.
dmg
Fri Oct 01 2010, 10:56PM
Thank you for your help Mary,
I was going to mount this capacitor directly to a metalic frame, but now I will mount it on a plexiglass platform first before that.
Fri Oct 01 2010, 11:06PM
There are insulated through-hole chassis mountings for this type of capacitor, but your way will do just as well if you don't want the negative pole connected directly to a grounded chassis.
teravolt
Sat Oct 02 2010, 03:37AM
Hi Gatedbreakdown and Proud Mary, the mounting stud is floating and the reading is false. if there is no dead short to the negitive the stud is just a mounting stud. I have recieved assemblies with them mounted on aluminuim.
dmg
Sat Oct 02 2010, 04:44AM
Makes sence, well, either way, I already had made the piece of plexi for isolation, and it fits just fine. but its nice to know in the future about these type of capacitors,
Thank you for your help everyone.
