  • Guests: 57
Driving a MOT
Thomas
Tue Sept 28 2010, 12:52AM Print
Thomas Registered Member #120 Joined: Fri Feb 10 2006, 07:07AM
Hi all.
I thinking of making a current limited and voltage regulated power supply for capacitor charging.
I'm thinking of making a PWM which controls a MOT.
I'd use a full-bridge topology, that drives the MOT's primary windings. The output of the MOT will be full-wave rectified.
Now I should be able to get a nice closed loop, fixed voltage power supply out of this by changing the duty cycle. I will add a current shunt or some sort of current regulation later. However, I don't think any over current conditions can occur because its an RC circuit. Though sweet shorts could occur.
I'm not trying to make this Energy Star as I know PWM's aren't too brilliant.
I'm just curious if this is a good route to take to get a 20V to 1805V power supply.
-Tom
Tue Sept 28 2010, 02:14AM
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
I think MOTs arn't ment for voltages other than 120/240. I thought if you put in any other very different voltage the voltages would sway/go crazy.
ScotchTapeLord
Tue Sept 28 2010, 02:47AM
I'd recommend just running it off mains with a variac, with a ballast if you need current limiting. This is much easier and MOTs are meant to be run off 60Hz. Not to mention fewer losses/spikes associated with the square wave switching...
I have used MOTs below their rated voltage with this exact method to charge capacitors. A variac will let you control the input voltage from 0-110 (because you're in 110 land), making the secondary's output voltage variable from 0V to ~2kV, which is close to what you're looking for.
Mains>variac>MOT>rectifier>cap
This is easier than making a SMPS!
quicksilver
Tue Sept 28 2010, 05:53PM
Is using a Variac even possible to achieve that effect with such a transformer? If a dip below a given point were reached would that not allow the functionality to be maintained?
Tue Sept 28 2010, 05:56PM
quicksilver wrote ...
Is using a Variac even possible with such a transformer? If a dip below a given point were reached would that not allow the functionality to be maintained?
Its just a regular iron core transformer with a core that is greatly under dimensioned to its power rating in its original form as a MOT.
It follows the standard rules for transformers with primary:secondary ratio to the input voltage, a MOT is generally 1:10 in EU and must be 1:20 in US?
Tue Sept 28 2010, 07:40PM
Mads Barnkob wrote ...
...generally 1:10 in EU and must be 1:20 in US?
is this because every socket in the EU is 240vac? and we americans use 120 or 240?
Adam Munich
Tue Sept 28 2010, 09:02PM
Yes. In the USA the MOT's are 1:20.
HazzWold 1993
Tue Sept 28 2010, 10:39PM
You can run a MOT with a light dimmer switch the way you would an ignition coil - Link2 with a 1uf microwave oven cap in series i got 1cm blue sparks, with a 14uf cap i got 1cm starting arcs not as big as a normally run MOT but the voltage appeared higher..
Wed Sept 29 2010, 01:41AM
HazzWold Labs wrote ...
yikes! i wonder if there is enuff line to line insulation, and i wonder what the line quality looks like for your house circuits, RFI too. using a SCR dimmer must be rough on a MOT.presumably you would aalso get much less power through the primary too, though the higher secondary volts makes sense as you are forcibly chopping the curretn faster then the normal 60Hz sine.
Thomas
Wed Sept 29 2010, 10:22PM
I sort of want switching only because then I can have full control digitally.
Would I run into problems if I run it at 60Hz switching? I'm not too sure what the cut off frequency of iron is. I assume if its too low it'd knock off the frequency components of my square wave and give me a rubbish output on the secondary.
Thats really the only thing I'm worried about. Also I should not have problems with 0 - 50% duty cycle at 60Hz being feed into the primary via full bridge topology right?
Thanks basically my only area of concern.
-Tom
