  • Guests: 44
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
World's brightest bike lights
1 2 3 4
Tesladownunder
Mon Sept 27 2010, 07:21AM Print
This follows from the thread You call that a ******* ? THIS is a ******* !!!
Note that I have disabled the full size pics and removed the Youtube promotional video. Sigh - such is the commercial world.
The project is one of 3 related and I will post the links here soon. The second will be the worlds most powerful flashlight and the last will be a Xmas project.
So, back to this project and some numbers.
Bicycle: Electra, "Townie" ladies bike, cream AU$1300. Chosen by my wife. Ladies bike??? Big advantages of step through and a front tray. No point in trying to make a heavily loaded racing bike or mountain bike I reckon. Old lady retro feel styling in cream. (I wanted the purple flowery one but my wife was firm).
Batteries: three 33AH deep cycle batts good for 12.2V 35A dropping to 12.0V at 12 mins. At 70A 11.8V dropping to 11.7A at 6 mins. Need to run 34V at 52 A peak (1.8kW) delivered to LEDs ie need to drop from (12.0 x 3=36) 36V to 34V. 2V drop at 50A is barely enough for heavy duty cabling and some big MOSFET's to do PWM. A lot of care will need to be taken with very low value load equalising resistors. This is all a bit on the edge.
Front LEDs I will use 11 x 100W cold white 9000 - 10,000K colour temp (that annoying blue like those expensive Xenon car healight. Rated at around 34V (32 - 36V) at 3.5A (3.2 - 3.8A) with luminous intensity 6000 - 6500 lumens from a 1.8cm x 1.8 cm surface. Roughly 10 watt light output by my calculations and hence have to lose the rest (90 - 110W) as heat hence the decent fans.
In addition to the forward facing 11 white LEDs there will be 3 coloured LEDs (Red green and blue all 100W 6000 lumen) facing forward to a total of 14 LEDs facing forward ie 84,000 lumens. The 3 coloured LEDs in total will be white but will allow me to run them separately to generate any colour.
For info on White 100W LEDs see my page on it
Rear LEDs 3 coloured LEDs (Red green and blue all 100W 6000 lumen) facing backwards. ie 18,000 lumens to the rear as well.
Total 100,000 lumens.
Electronics. I have a PIC driven MOSFET motor drive kit for 40A at 24V which I will adapt. to rate 70A MOSFETS's x4 in parallel are IRF1405's. 55V 169A. Peak voltage is a bit close but nothing much inductive here. The front RGB LEDs will be swithched into the main PWM or onto an individual circuit.
Lots of other stuff has been planned but this is a start. Now for some pics.
BTW I am promoting this as the worlds brightest bike light lights because the brightest I could find were my previous single 100W set at 6000 lumens and someones Halogen set at 6500 lumens. If you can find a brighter set (in lumens not candlepower) PLEASE tell me.
Checkout the Youtube vid first though.
1285571724 10 FT0 Ledbikeplans1 1285571724 10 FT0 Ledbikebattsbikefloor387
1285571724 10 FT0 Ledbikeparcels3 1285571724 10 FT0 Ledbikeparcels3threefans
1285571724 10 FT0 Ledbikeparcels4bike12fans 1285571724 10 FT0 Ledbikerearlightscarrier
1285571724 10 FT0 Ledbikeseatedsinglewhite 1285571724 10 FT0 Thisisa
Coronafix
Mon Sept 27 2010, 08:35AM
I don't get it.
Your just going to piss off oncoming motorists.
Mon Sept 27 2010, 09:33AM
Coronafix wrote ...
I don't get it.
Ahahahaha, lol
This is going to be like a death ray 0.0
Tesladownunder
Mon Sept 27 2010, 10:18AM
This is not meant to go on the road any more than a monster truck or an F1 racer is meant to go on the road. They are the expressions of the strongest and fastest extreme versions of the 4 wheel "car".
But we still enjoy watching them in their place.
These bike lights should never be shone at oncoming traffic. Nor the brake lights either. This is a display bike. I will have a very low power setting of a few watts that will suffice for road use and probably have a standard bike light set for emergencies.
Mon Sept 27 2010, 02:45PM
Peter,
Those batteries must weigh at least 20lbs each. How are they going to be mounted to the bike?
-Dave
Killa-X
Mon Sept 27 2010, 03:04PM
I can see something like this good for mountain biking or something similar at night. It wouldn't be smart to use it on the street, but with such bright lights it would be great for night riding in a woods, trail, etc. I think it would be good to have a power switch or PWM so you cab turn it down if you have to ride on the street, so you don't blind passing drivers!
Tesladownunder
Mon Sept 27 2010, 07:35PM
Killa-X wrote ...
Sorry, this is definitely NOT a mountain bike setup. Apart from TV and print media, I envisage this being used in static displays, at bike shops and shows. I won't get many miles on the clock. It has 3 internal gears but is nothing like a proper bike to ride.
Dave Marshall wrote ...
Batteries are 10kg each ie 30kg.
Two possible mounts. In fact the high one is simpler and not as much of a problem as I thought. Hopefully a lot tidier too. Some of the Electra series bikes have side wicker baskets which might be OK if they fit.
The low slung mount at the rear can be lifted with a lever and doubles as a stand. A good stand is really important as this is fragile stuff.
1285616025 10 FT97378 Ledbikerearbattsplan2 1285616026 10 FT97378 Ledbike3battsbike
Mon Sept 27 2010, 08:22PM
I can see a use for these mounted onto the back of a car if someone is tailing you. Boy, would that person be surprised!
Adam Munich
Mon Sept 27 2010, 09:13PM
Have you considered lithium batteries?
mikeselectricstuff
Mon Sept 27 2010, 10:44PM
I reckon you could get something brigher in that volume using a bunch HID lamps or UHP projector lamps. Would probably need liquid cooling though.
Or maybe just just one big xenon-arc lamp as used in follow-spots or movie projectors.
