  • Guests: 91
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Push pull SMPS - feedback?
dmg
Tue Sept 21 2010, 06:22AM Print
Hello everyone,
I am just still trying to get an idea of what to build, but the general interest is to make a power supply for a small coil of mine, with a voltage range of 300-400VDC or so.
the one thing Im having an issue with, is desiding the style of feedback/driving method.
my original method was just to use an oscillator, but I think feedback would be preferable, however I searched around, and Im still stumped on just how to do this. current transformer on the secondary side perhaps?
if you know any methods of feedback either then a CT, or if you find any faults with this design, I will greatly appreciate your help.
Thank you.
1285050129 2628 FT0 Pushpull
-Edit: diregard SNB capacitor.
Tue Sept 21 2010, 08:15AM
Real good quality SMPS never use self-oscillating feedback, as far as I know. It's always an oscillator built into the controller chip.
The cheap ones (electronic ballasts for fluorescent lights, solid-state NSTs, electronic transformers for 12V halogen lamps) use a self-resonant circuit with BJTs as the power devices. But it's hard to vary or regulate the output voltage of a self-oscillating SMPS.
Most SMPS don't have a resonant transformer anyway. Only the latest designs that are shooting for lots of watts per cubic inch, and those run special controller chips meant for resonant circuits.
Supplies running off the line never use that push-pull topology either, because the devices need to be rated at pi times the supply voltage.
teravolt
Tue Sept 21 2010, 07:33PM
How much current do you want to generate and what type of regulation are you looking for? You could make a mazilli circuit with your own windings on a flyback and make a emitter follower regulator with 1500v TO-3 transistor. Current is the determining factor
