  • Guests: 52
Elliott (35)
Gratitude (40)
Swraka (37)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
Programming PIC controller PIC18 using a PIC16 hardware.
cavemen
Thu Sept 16 2010, 04:59AM Print
cavemen Registered Member #2008 Joined: Tue Mar 03 2009, 05:11AM
Hello.
I stumbled on another problem.
I started to build a PIC programmer and geathered all the parts and I am almost done.
This programmer can program everything up to 18 pins. THe design came from this website:
PIC18F4550 has 40 pins.
Can I use this same circuit to burn the 40 pin pic18?
All pics should have the nearly-same protocol, but I am not sure how to modify by circuit and connect it with jumper wires to the breadboard so I can program this PIC.
Here is a pic184550 pinout. Link2
Here is the pinout for pic16f84 :http://www.best-microcontroller-projects.com/ image-files/chip-pinout-16f84.png
The programmer is universal so it is kinda hard to get what pins really need the signal/voltage/ground at the time of programming.
Solving this mystery by laying pic12 and pic18 over the circuit to find the right pind doesn't work. The eight PIC12 pins are so multifunctional that it is very hard to understand how that circuit even works.
Should I build another programmer for pic18?
Thank you for your time.
Jdm
Is this the fundamental circuit for a programmer I am seeking?
(second one from the bottom)
cavemen
Thu Sept 16 2010, 06:57AM
All programmers seem to have same components.
Is this waht everything can be simplified to when it comes to programming a PIC controller of any size: Link2
Bjørn
Thu Sept 16 2010, 07:03AM
Go to the microchip website and look up a document called "Flash Microcontroller Programming Specification" that applies for your chip, it will tell you what pins to use and what types of programming it supports.
Even better, get a PICkit 2 Link2
It can be had for cheap on ebay and other places and will make your life a lot easier. Home made programmers generally are a pain, particulary on modern computers. They tend to refuse to work with some chips and cause a lot of frustration.
Electroholic
Thu Sept 16 2010, 12:04PM
only 5 pins are used during programming, it is called ICSP. Link2
big5824
Thu Sept 16 2010, 12:48PM
Id second the pickit 2, iv successfully programmed 16F887s and dspic33fs with mine, so im pretty sure it can handle everything inbetween
Bjørn
Thu Sept 16 2010, 01:16PM
It does and it even has a programmable voltage output for driving small projects at different voltages and a 3 channel logical analyser among other features.
Have a look for example here: Link2,739,786&Prod=PG164120
cavemen
Fri Sept 17 2010, 06:24AM
Thank you.
Now i get it all.
I found an article that was written by someone who tried to build a programmer.
Bigger PICS = Easier pinouts.
