  • Guests: 38
09/16 Michael Witt (36)
09/16 AleSeg (15)
09/17 Jyardana (41)
Ionic Disassociation of Water in a Plasma field
Tue Sept 14 2010, 10:01AM Print
Registered Member #3195 Joined:
I'm researching Stanley Meyer's water fracturing to fuel. I have found many different strange effects of water when applying different types of energy. I'm posting here because he was using HV circuits & design similar to the tesla coil circuit. I found Eastern Voltage Research on this link and looked around to find there Plasmasonic ii best resembles the circuits used by Meyer. And hope to be able to obtain the knowledge and assistance needed to carry on with the research. Thank you in advance to anyone who can help. Hopefully I am able to help some people here with answers and videos I'll post along the way.
Here are 2 videos to compare and demonstrate. A 6kv 30ma neon trans is being used to generate positive charge or negative charged plasma field.
[b]THE WATER USED IN EXPERIMENT ONLY PASSED 0.06AMPS @110VDC BEFORE START OF EXPERIMENT. THE SS WIRE ALSO DOES GET HOT ENOUGH TO DRIP MELTED PIECES INTO THE WATER/b]
This vide shows a negative charge running from the SS wire to water suface.
This video shows a positive charge running from SS wire to water surface.
I believe this along with a couple of other experiments I've done to show some type of validity to the Water Fuel Cell work Meyer's did.
Visit forum links for a full theatrical description of fracturing water into fuel process and explanations of the parts working at hand.
Link2,1239.0.html
I'm giving these links because there is too much info to be seen before dismissing as bunk.
Tue Sept 14 2010, 10:48AM
Our party line is that the energy in Meyer's experiments came from the aluminium wire. Aluminium burns just like magnesium, if somewhat harder to ignite, therefore it's a form of fuel. And it's quite plausible that when burned under water, it could give aluminium hydroxide and hydrogen.
So, no free energy. Because aluminium is produced from ore by electrolysis, Meyer's water car was really just a stupendously inefficient electric car. I believe the other moderators will stand by me on this, if I decide to lock your thread in a while for free energy bunk.
Tue Sept 14 2010, 11:41AM
Utter bollox!
Tue Sept 14 2010, 11:56AM
Proud Mary wrote ...
Utter bollox!
I was trying to be a bit more diplomatic about it smile
Tue Sept 14 2010, 02:33PM
i haven't ever seen a reference to aluminum wire used in any of the info Meyer left behind. Could you please send me to the link you found with this info? I have found evidence Meyer was lying. I will not say he didn't try to keep a few things back. Or place the info scrambled as if he was ADD. I can only guess he did this to prevent theft of his design. It would require researching & understanding each part of the system for it to work as a only fuel. Have you ever seen anyone use a tesla coil circuit replacing the top load with SS tubes inside each other such as Meyer used. Of course it would require a slightly different set up for the resonators primary & secondaries as well. I have studied this for over 5 years learning it from the basics up. I can if you keep a open mind explain using basic text book physics examples. I have met with 2 guys from DOE working out of Wright Patterson AFB who I tried to dig to find info. But got nothing more then the cold shoulder with the statement "It's classified". There is more to this then anyone wants to believe or try to understand. This is not changing lead into gold or vampires here. But real science that needs real attention not blown off because of laws that were written which might possibly have a place where there are unknown exceptions because nobody looked for them. I have many things I researched like this system and several things suggesting electrical magic in many shapes and forms deal with phasing, impedance matching, reactive power along with other parts of physics not thought to be combined yet for net gain. A friend once sent me a quote "If we knew what we were doing. It wouldn't be called research". smile
Tue Sept 14 2010, 03:09PM
Here are several links to some very informative and important to this research
The Water Fuel Cell of Stanley Meyer
International Independent Test Evaluation Report
my post at building for tomorrow
Link2,135.0.html
Info on Ultrasonic Mist aka cold fog gen
Jnaudin WFC experiment
water explosions page
The Electron Phase Shift
Pulsed Power Transformers info to possibly apply to WFC
Flux Compression Generator- Fcg's being used for free energy. The USA military use this to power its high energy weapons. (Status classified by the USA)
flux compression gen capable of producing terawatts of power
along with the FCG u need to know they are using Metaglas power pulse cores
MAGNETIC PULSE COMPRESSION (MPC)
Magnetic pulse compression utilizes reactors in conjunction with capacitors to shape input pulses into narrow output pulses of much higher current . MPC, therefore, allows the designer to use less expensive input switches with lower current ratings. MPC can also extend the lifetime of the input switch. Advanced MPC devices - capable of generating power levels of multi-terawatts in tens of nanoseconds - have been realized utilizing Metglas® cores.
This product may require licensing for export outside the United States:
Please visit the U.S. Dept of Commerce website to understand the necessary requirements. ( Link2 )
Metglas®, Inc. requests that the applications and approval accompany any request for samples, quotations, or purchase orders.
MinorityCarrier
Tue Sept 14 2010, 09:14PM
Hoo boy, Bandini aplenty.
Wed Sept 15 2010, 06:27AM
hmm.. i met someone at 'uni who was building one of these things for his final year project. I did point out that it was highly likely to not work, but he ignored me.
(this was before meyer got arrested on fraud charges)
interestingly a very similar device (based on regular electrolysis) does generate oxyhydrogen (aka H2 and O2) for burning in a modified torch, these have been used for a while to save on expensive acetylene but draw a lot of power in the process.
-A
Chris Russell
Wed Sept 15 2010, 09:01PM
Chris Russell ... not Russel!
Free energy discussion is not welcome here. Please see the rules regarding pseudoscience.
Thread locked.
