  • Guests: 74
how cm bricks current limitter works?
Gregory
Sun Sept 12 2010, 05:09PM Print
it turn off the igbt brick, is a fuse that blow? how work?
Mon Sept 13 2010, 12:30AM
Gregory wrote ...
In short, it clamps the gate to ground whenever there is enough voltage dropped across the D-S.
Mon Sept 13 2010, 11:17AM
Sort of, it drags the gate voltage down so that the current passing through the brick is limited to a safe level. It doesn't turn it off completely.
I've seen Tesla coilers open the lid of the brick and snip the wires to the current limiter circuit, disabling it.
Goodchild
Mon Sept 13 2010, 06:44PM
Steve McConner wrote ...
Yes this is very easy to do if you know what to look for, take a look at my DRSSTC 2 thread, it has pics that show how to disable the limiter in a CM300DU-24F Link2 it's a very similar processes for other bricks.
Marko
Mon Sept 13 2010, 10:52PM
Hm - could one leave the current limiters in the igbt's in case they are not going to be ran at more than their rated current, or is it just completely unwise to do in a DRSSTC in any case (desaturating the igbt with 600 amps through it sounds like no good).
Marko
Goodchild
Tue Sept 14 2010, 12:01AM
It seems to be a wast of an IGBT, why use a IGBTs at 600A when it's capable of 1200A?
dmg
Tue Sept 14 2010, 01:34AM
Id belive its more reliable anyway keeping parts in thier if not under thier ratings,
at least thats the case with whatever I built, this way its rare for me to kill IGBTs and MOSFETs.
