  • Guests: 20
Jack (13)
04/25 Desmogod (48)
04/25 Alex Smith (31)
04/26 Bead (41)
My DRSSTC 2
Goodchild
Mon May 24 2010, 07:03PM Print
Well after much work (still more work to be done) I figure I should show off my DRSSTC 2 cheesey
Well I guess ill start with some specs:
Secondary: 18x4.5 1800 turns 30 AWG
Topload: 18x4.5
Fo: 105KHz
Tank cap: 0.2uF 8KvDC
Power electronics: CM300DU-24F half bridge
with doubler (CM00DU-24F has had the current limiter removed shades )
Controller: Steve Ward's UD2.0
Here are some pics of the coil:
4636577952 560595938b
Original pic: Link2
4636579198 D2f84a10c0
Original pic: Link2
4636578532 9e49d34f25
Original Pic: Link2
And now some sparks!
right now 60 inches is my current limit (that's 3.333333x) because the
garage is just to small, will have to wait to take it outside wink
4635904033 7b6846fcf0
original image here: Link2
Also here is a video of it running in the garage: Link2
Mon May 24 2010, 08:31PM
Very nice! I love all the LEDs, and for some odd reason i really like the simple building material! I have a request. When you get this puppy somewhere larger, I'd love to see a breakout point on the side and some ground strikes! 3 times the coil length is plenty :-o and you say you can push it harder smile. Seeing a half bridge kick so much butt kind of makes me want to make one with my CM200DU-24F.
How did you remove the current limiter? That sure is puzzling! And it seems these CM series bricks have a tan-ish color to the insulating gel inside, so you cannot see the parts. How did you get through all of that stuff?
I will be waiting for updates!
Luca
Mon May 24 2010, 09:07PM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
Very impressive!
I think that the IGBTs your are using are a bit oversized for such coil...
Anyway, very good results!
Luca
Goodchild
Mon May 24 2010, 09:09PM
Arcstarter wrote ...
Thanks for the complements! cheesey
Any way ya the goop is a pain in the butt, I got 4 CM300DU-24Fs from ebay I was lucky that the first one I tried to open up had clear goop amazed
To disable the current limiter (RTC) all you have to do is cut 2 wires but you have to be careful not to cut the third wire going to the gate.
This is my Brick:
4583736603 D631988a90
This is Bart Anderson's brick:
CMRTC
Goodchild
Mon May 24 2010, 09:11PM
Luca wrote ...
Very impressive!
Luca
Thanks
Ya I know they are over kill, but that's the point! This way they will almost never blow up again wink
Sorry for double post don't kill me!
Coronafix
Mon May 24 2010, 10:52PM
Beautiful layout, neat and elegant!
doctor electrons
Tue May 25 2010, 02:15AM
Not only does it work, its a beautiful piece of artwork!
Awesome! Fantastic job!!
Goodchild
Tue May 25 2010, 02:54AM
Thanks very much cheesey
teravolt
Tue May 25 2010, 03:34AM
Hi Goodchild, nice work. Does the cm300 speed up when you remove the limmiter? Do you think it could be done with a cm600?
Goodchild
Tue May 25 2010, 03:57AM
teravolt wrote ...
Disabling the RTC didn't speed up the bricks, It just allowed me to push more current through them.
The only way I could run the CM300 at such a high Fo is because my coil uses Steve Ward's new driver which incorporates
phase lead to switch the large bricks before the zero crossing, this yields near perfect ZCS ( and no ringing smile )
4627135827 78190db517 O
4627135841 C2a7208518 O
4627741312 024fe88e02 O
As for trying it with CM600s I bet it could be done, although phase lead dose have it's limits.
