  • Guests: 32
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Bismuth magnetic field tester
radiotech
Sun Sept 12 2010, 03:58AM Print
Has anyone experimented with bismuth resistors to probe magnetic fields. These were made by sucking molten bismuth up thin lime glass tubes (carefully) and attaching 2 leads to each end
one pair to inject a current and the other pair leading to a (potentiometer) a voltage bridge calibrated in milivolts for measuring thermocouples.
Bismuth changes resistance in a magnetic field.
It would be fun to test the new supermagnets. This gadget was used on magnetron magnets.
A reverse pipette embouchure was needed to get the Bi up the tube and not have the glass break.
Fri Dec 31 2010, 10:37AM
this is a worthwhile experiment, I must try that.
just curious but has anyone tried this with a bismuth/tin or bismuth/indium alloy? would seem easier to fabricate.
-A
Shrad
Fri Dec 31 2010, 12:05PM
hi,
why not use bismuth alloy wire? I know this exists in solder wire bundles on ebay from time to time...
that would make some nice gauss-meter, and quite precise too in a wien bridge arrangement...
just my two cents ;)
radiotech
Fri Dec 31 2010, 04:13PM
These flat bismuth spirals were used long ago to
slip into the clearance space between rotor and stator
of electric motors to investigate magnetic fields.
When I made these for myself, there were problems
with the wires entering the ends of the tubes in contact
with bismuth acting like thermocouples.
