  • Guests: 27
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Question about isolation transformer
Renesis
Sat Sept 11 2010, 08:41PM Print
Renesis Registered Member #2028 Joined: Mon Mar 16 2009, 08:13PM
Hi everyone.
My school just got hold of a 3phase 1:1 transformer wired in star/delta configuration, to convert the 230V mains to 400V. This would be used to supply power to some foregin equipment. It turned out to have a shorted winding, so the entire thing will be scrapped.
What i want is to convert this transformer to a 1phase isolation transformer for my workbench, avoiding the faulty winding altogether. But as it is now it's too big and too heavvy for my use, so my question is; How much of the core can i remove? Could i simply unscrew the bolts holding the cores together and remove the crossbar at the top and bottom, or would that cause the transformer to malfunction?
The transformer i am talking about looks similar to the one in this picture:
1284237603 2028 FT0 Transformer
Thanks.
radiotech
Sat Sept 11 2010, 09:25PM
Dont take any of the core off. Just put your coils on the middle leg.
The star delta conversion also does other things in addition to voltage ratios and isolation.
if one winding is shorted why not leave the other two in place, disconnected on the end legs the windings should slide off.
take a look at magnetic amplifier configs using 2 leg cores.
Renesis
Sun Sept 12 2010, 04:24PM
Do you mean that i cant remove any of the core, or just that i dont have to? For you see the main reason i asked is that the transformer is, as it stands now, to heavy and too big for my use. I could remove one core leg as you suggest, but the transformer would still be on the heavier side.
Could i remove two core legs and use only the third, or would that cause the core to saturate and whatnot?
Sun Sept 12 2010, 05:00PM
it has to have at least a single closed loop of core material. Or it wont work for sine waves. I would not dissasemble the core in such a way that you cant get them back to gether again. you might be able to get rid of the shorted winding, but disconecct it for now leave the core to big and heavy and test it to see if thats really going to work for you, theres no need to do a whole lot of work to it, just to find out its dead.
radiotech
Sun Sept 12 2010, 05:59PM
The coils disconnected wont do anything, but add weight. If the sliode off easily, keep them for future use. Its had to judge from your pic how big it is. Another thought, Have the school fix it a lab project- something in which the students learn something practical.
One school here had the shop kids make welders that they took home for just the metal and wire cost. When they cleaned out the storage they gave me two *heavy* rolls of the iron plate the cores were made from.
Renesis
Sun Sept 12 2010, 06:13PM
I see. I'll just keep searching for a more suitable transformer then. Thanks for the replies.
Edit:
Oh i can assure you, i still wont let them throw it away that easily wink
Tue Sept 14 2010, 12:33PM
Have a look to see if the core is welded together,
if it's not then dis-assembly AND re-assembly are quite simple.
You will need to remove the former with the windings that have the short-circuit.
If you can remove the iron of one of the three limbs then you will have two primaries and two secondaries to adjust input:output ratio.
If you can't remove the iron for one of the limbs then just use the center limb for one primary with one secondary.
