  • Guests: 30
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Pretty powerful mosfets
Adam Munich
Wed Sept 08 2010, 09:36PM Print
I've been playing with some of these lately. They are really powerful, and they don't even need a heatsink at a continuous 50 amp 24V DC load. They don't like the inductive kickback of a flyback very well though...
Anyway, you can get them here in packs of 12. Link2
Apparently fairchild has a whole line of "ultrafets".
ScotchTapeLord
Wed Sept 08 2010, 09:47PM
I guess that's because they're only 100V... since you get 12, maybe you could series a few?
Adam Munich
Wed Sept 08 2010, 09:50PM
Maybe, but I would think a diode would work better. I burnt out 5 already, and I don't want to kill the rest. They REALLY don't like kickback.
Thu Sept 09 2010, 02:27AM
I used the Ultrafets years ago to build an inverter, for converting 24V DC to 240V AC. They worked great, but they're an almost 10 year old design, and MOSFET technology has probably improved quite a bit since. But who cares if they're cheap on Ebay smile
As was mentioned, not the best choice for driving a flyback. The flyback has to be allowed to make that inductive kick on the primary: it's necessary to generate the high voltage on the secondary. If you use a 100V MOSFET then all the energy that should have gone into your arcs will just be dissipated in the MOSFET and burn it out.
Another way to drive a flyback is using a bridge-type driver and getting the high voltage by resonance. That would work better with these MOSFETs.
