  • Guests: 206
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Gate drive: Transformer or IC?
Wed Sept 08 2010, 10:50AM Print
Which is better?
I'm going to build Dr. Kilovolt/Jan's Plasma speaker circuit (yes, another plasma speaker) which looks like the best performance and simplicity; I'm thinking of making a chamber with Helium for the arc but that might be too ambitious. For the "Better output" stage a gate transformer is used. I recall from one of the threads I found in my scearching (but then forgot) someone put a gate drive IC somewhere to get a cleaner wave form. So I'm wonder wwhich would be better.
Which one would give better sound quality?
Do need a special setup up if I use an IC or just wire the I/O was in it's datasheet?
ScotchTapeLord
Wed Sept 08 2010, 01:08PM
GDTs offer simplicity of design but must be optimized for a particular frequency.
ICs require isolation, so you'd need a separate supply for each gate, whereas the separate windings of the GDT provide isolation.
Wed Sept 08 2010, 02:13PM
Oh, didn't see that thread =S
Sorry, Well I guess that Answers my question >.<
