  • Guests: 53
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
winding a secondary on a flyback core
1 2 3 4  last
ZakWolf
Mon Sept 06 2010, 01:42AM Print
i have a flyback transformer core an wanted to make my own windings and i read some where that there is a ration, and was wondering what i would have to do to insulate it.
Adam Munich
Mon Sept 06 2010, 03:34AM
You would have to turn a few thousand windings of thinner than hair wire to get anything decent. It's not worth it IMO.
ZakWolf
Mon Sept 06 2010, 04:15AM
i was thinking a few hundred, with thick wire to get about a 5 kv at high current
Adam Munich
Mon Sept 06 2010, 04:22AM
The core is way too small and will get saturated. It's designed for a very large amount of tiny windings, and an operating frequency in the kHz range.
Wolfram
Mon Sept 06 2010, 08:08AM
What? Many people have made their own flyback secondaries with good results.
Mon Sept 06 2010, 08:29AM
around 1000 turns is OK, the biggest AC flybacks have some 2500 turns, and 750 turns for the ones used with a multiplier(cascade).
ZakWolf
Mon Sept 06 2010, 10:16AM
what gage wire should i use
Adam Munich
Mon Sept 06 2010, 02:48PM
That depends on how many turns you want, what current you'd like to pull, and the size of the core.
Antonio
Mon Sept 06 2010, 05:11PM
Insulation is the big problem. The whole winding must be encapsulated in insulating material, as wax or mineral oil, for good insulation, and the winding layers must be separated by insulating layers. Waxed paper is usually enough. Interesting project if want to learn how to do it, but it will be difficult to obtain something better than a commercial unit.
Matt Edwards
Mon Sept 06 2010, 06:41PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
It is possible to wind your own secondary. As already suggested here I have read that you will need at least 500-1000 turns for decent results. However I would recommend more unless you want to produce lower voltage higher current arcs. Find a small thin piece of tubing (plastic/cardboard/paper) that you can slide the core into and wind the wire on the tubing. It will make your life much easier. I would recommend somewhere around 32awg or thinner. Also every homemade flyback secondary that i have seen used fewer and fewer turns for each layer of windings for capacitance. In my understanding it will be similar to rolling your own capacitors but you will be using layers of wire rather than sheets of foil.
Here are a few youtube videos that may be helpful or at least give you a few ideas...
Link2 (this one didn't turn out well due to poor insullation also possibly air between layers. Notice the corona in the secondary between arcs)
Link2 (decent explanation of construction about half way through the video)
Link2 (400 turns, hot arcs)
Link2 (I threw this one in here because it has to be one of the biggest ferrite cores i have ever seen)
Link2 (4hv thread about winding secondary)
There is also some good information here.
Link2 (Inductor and Flyback transformer design pdf)
Link2 (Good information/calculators at bottom of page)
Link2 (flyback design calculator)
Lots of good information out there. You may have to do some searching online.
1 2 3 4  last
