  • Guests: 33
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
How can you test for a bad capacitor
Sun Sept 05 2010, 05:14AM Print
I fried some components some time ago on my inverter. I measured the capacitance of each metal film capacitor and they seemed ok. Yet, when I ran them at 100khz it seemed that they were partially shorting, and causing my inverter voltage to sag heavily. I replaced the capacitors and everything worked perfectly.
So, if the capacitance is good under static conditions, how can one tell the dielectric is failing? Their rating is 0.22uf, so I would think timing how long they hold a charge would be difficult.
Sun Sept 05 2010, 07:16AM
Measure the leakage current?
radiotech
Where I worked we bought one of these :
We tried to use it to analyse induction heater oil capacitors
to see if failures could be predicted in a Calcoil machine.
It didnt.
Then we built a High voltage DC hypot leakage tester and picked out a few dodgy ones from the modules as they came for repair.
Finally after gathering a box of about 100 bad capacitors we complained so loudly the capacitor manufacturer admtited they had a bad lot and replaced them all
Sun Sept 05 2010, 08:26AM
yeah, testing under rated voltage usually identifies failing parts.
another trick is to heat up / cool down the part, a good one won't change much but a bad one will.
regards, -A
radiotech
Sun Sept 05 2010, 03:06PM
There is another test done on very large motors to determine a 'polarization index' which measures how much water the machine sucked up while it was switched off. These tests are a part of startup
after a plant has been down for extended maintenance. It very well may be that the seal broached on the small film capacitors allowing moisture to get in. They might then present a different leakage depending on polarity. A HP valve VTVM has a 100 meg DC input and can show if a capacitor shows electret properties.
A thermal imaging camera also could show which of a group were getting hotter during operation.
Matt Edwards
Mon Sept 06 2010, 06:49PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
This may be helpful for testing current leakage...
Tue Sept 07 2010, 05:23PM
Film or film/foil capacitors can die slowly as internal faults get vapourised, causing a drop in capacitance.
Since you say the capacitance value measured is correct it isn't that.
Leakage current should be virtually un-measurable,
check a data sheet for your type of capacitor.
If the capacitor has been subjected to large impulse or rms currents the wire-to-foil/film connection (schoopage) can degrade, increasing esr, which is difficult to measure simply.
The result will be overheating.
Possibly you are over-volting the capacitor(s) due to resonance etc. ?
I would expect to see a slow loss of capacitance in this case.
For almost all film capacitors, if it feels hot then you're over-stressing it.
P.S. Have you looked at a datasheet for your capacitor or similar type?
You will find that the permissible rms voltage at 100 kHz is MUCH less than at 60 Hz.
