  • Guests: 35
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
outboard pass transistor
Sat Sept 04 2010, 03:23AM Print
Why can't an NPN be used instead?
1283570632 190 FT0 Boosti
radiotech
Sat Sept 04 2010, 05:02AM
Would it work with a 79xx regulator instead?
Marko
Sat Sept 04 2010, 03:36PM
IamSmooth wrote ...
Well, if you wish to increase regulator's current capability while keeping it's exact voltage, you need to use a PNP transistor this way.
You could use an NPN like 2N3055 as a voltage follower, by connecting the base to the regulator output and passing the supply through it. This will allow for lots of current but will add the Vbe to the output voltage, and regulation will depend on characteristics of the transistor (very poor in case of 2N3055).
Other than that, you could build the whole regulator yourself, using an error amplifier and a reference source. Look at this page for some more advanced designs: Link2
Sat Sept 04 2010, 03:46PM
But why won't it work with an NPN? If the collector is connected to the supply and the emitter to the output of the regulator, why won't it boost the current when the base is on?
Sat Sept 04 2010, 04:28PM
I had to post again to add the picture. The question is what is the flaw with using an NPN instead of the PNP, and not what other solutions are available. I would think that the base gets a voltage allowing current to flow through the NPN as needed. So, what is wrong with this and why is the pNP the right choice?
1283617702 190 FT95831 Pass
Marko
Sat Sept 04 2010, 04:34PM
If connected like in your picture, the voltage emmiter will attempt to follow whatever the voltage is on the base - and hence you'll get output voltage nearly as high as your Vin, with little or no load - hence no regulation at all with this circuit.
Marko
Sat Sept 04 2010, 07:29PM
Oh.
I can see, then, that with a pnp and the emitter connected to Vin it will work.
Why doesn't the collector try to follow the voltage with a pnp?
How does one decide when to use a pnp or an NPN?
MinorityCarrier
Sun Sept 05 2010, 01:52AM
You can swap emitter and collector on a bipolar transistor, but it will work poorly. Forget trying that.
A pnp transistor has the base negative .6v (silicon) with respect to the emitter for the transitor to conduct, the emitter >>.6v positive with respect to the collector. A npn transistor is the opposite, the base must be .6v positive with repect to the emitter for the transistor to turn on, the collector is >>.6v positive with respect to the emitter. One decides to use a pnp or npn based upon this.
One way to model these in your mind is the difference between the base and emitter voltages is .6v. For a pnp, the base is .6v lower than the emitter, for a npn the base is .6v higher than the emitter, assuming there is not a lot of current limitation on the collector.
An emitter follower circuit is basically based upon that difference, the emitter voltage follows the base voltage with a delta of .6v once again so long as the collector current is not too limited (you need some base current limiting with resistors otherwise you'll blow out the transistor).
The bipolar transistor is a current amplifier, the transistor beta or Hfe is the collector-to-emitter current divided by the base-to-emitter current.
