  • Guests: 136
IRFP 260 or 460
Adam Munich
Fri Aug 27 2010, 05:24PM Print
What would be better for driving my giant flybacks? The 260 or 460? The 250's can supply more amps, but the 460's seem more robust.
Daedronus
Mon Aug 30 2010, 07:44AM
I think it all depends on the input voltage and drive topology.
Right now I'm also playing with flybacks transformers, driven in flyback mode (single low side switch) and with 12V and irfp260 works great. The arcs start at about 5cm.
With 460 the arcs are far less impressive... obviously.
The back emf voltage spike is close to 200v so I'm trying to add some form of clamping.
There is also the fact that this mosfets are avalanche rated, so my understanding is that occasional over voltage spikes won't kill them.
Mon Aug 30 2010, 11:17AM
I have found the IRFP260 to be a more robust MOSFET than the IRFP460. Just make sure the voltage ratings aren't exceeded.
Mon Aug 30 2010, 12:49PM
Up to some 20-25 volts supply for your single MOSFET flyback driver, Id use the 260. Above that voltage use the 460.
Adam Munich
Mon Aug 30 2010, 01:15PM
Okay, I'll go with the 260.
