  • Guests: 35
  • Most ever online: 596
    Guests: 596, Members: 0 on 25 Oct : 21:25
WaveRider (62)
Njubster (34)
10/30 Aragorn (41)
10/31 Tor (40)
10/31 RussT (67)
1W laser cutter from old CDROM drives
Thu Aug 26 2010, 09:15PM Print
found this on Hackaday...
this is pretty neat, and demonstrates that you don't always need >20W of laser power to do neat stuff.
interestingly the same should work with a Bluray or 445nm diode with much finer focus and the ability to cut very sharp grooves in black/clear plastic.
Discuss.
-A
#include "SAFETYGOGGLESFOR$DEITYSSAKE.h"
"Bother" said Pooh, as he dropped the antimatter container...
Marko
Fri Sept 24 2010, 10:13AM
Hi,
I'm wondering about one thing - is it technically possible to focus output from a diode array like this Link2
into a spot suitable for cutting, apart from using fiber optics or pumping yag rods at a great efficiency cost?
If possible it would make a really affordable cutting laser.
Marko
Adam Munich
Fri Sept 24 2010, 07:54PM
It is possible to focus it, but the spot will be a line about .25mm * 3mm. Since it an array it is a multimode beam, and instead of a pinpoint it focuses to a miniature picture of the diode faces. Because they're all in a line the focus is a line.
You could use some cylinder lenses and careful alignment, but then a fibre optic would be much easier.
Also, 808nm isn't going to cut most things. A lot of things reflect 808 very easily.
