  • Guests: 60
SAQ Transmitting - May 16th, 17th, 18th
Chris Russell
Sun May 14 2006, 12:58AM Print
Chris Russell ... not Russel!
Grimeton Radio/SAQ is going to be transmitting on May 16th, 17th, and 18th at about 09:30-10:30 GMT each day, on a frequency of 17.2kHz. Anyone can listen in -- all you need is your soundcard and some wire to monitor the transmissions. See here: Link2 for one possible setup. If anyone's interested, I can attach a file with all the settings already in place for Spectrum Lab.
For those who don't know, the Grimeton VLF transmitter is located in Grimeton, Sweden (near Varburg). The transmitter generates its RF by means of an Alexanderson alternator -- the last one known in operation. That's right, no tubes, no transistors, just a huge RF alternator feeding 200kW into an antenna consisting of 12 wires, each 2.2km long, on top of six 127m tall towers.
Hope there's some interest! I'll post my results here, but I'd also like to see results from others. Questions on how to receive? Post them here, I'll help. smile
Sun May 14 2006, 06:56PM
What would I expect to 'hear' or is it CW or what?
Chris Russell
Sun May 14 2006, 07:04PM
Yes, it is hand-keyed morse code. If you're using Spectrum Lab, you'll be able to play with the settings a bit, to make the 'dits' and 'dahs' visible. I believe there is a preset called 'tape morse reader' or something to that effect, which would be most effective. Of course, you can also use the USB down-converter to shift the audio into the audible range, and decode it by ear.
If I am able to receive, I will try to provide screencaps as well as mp3s of the transmission.
Bjørn
Sat May 20 2006, 09:29PM
The closest I got was a signal on 17.179 kHz that I have no idea where came from. I got a row of different pulses on 15.2 kHz but that is nowhere near the correct frequency.
1148160590 27 FT9510 Signal
