  • Guests: 27
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Capacitive discharge magnetizer
Matt Edwards
Sat Aug 21 2010, 07:49PM Print
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Does anyone have information on how to make a small capacitive discharge magnetizer? Would it be significantly more difficult to build then a small induction heater?
Sat Aug 21 2010, 11:14PM
I suppose that it depends upon what you want to magnetize,
NdFeB would be a challenge,
for my AlNiCo horseshoe magnet I just used an old transformer core, just the 'E' parts
and wound as much of the thickest magnet wire I had on the central limb using the original former.
put the magnet from centre pole to one limb
and discharged a 10,000 uF cap into it, not calculated but I know that there was very little current reversal due to the LCR values.
You can use Barry's coilgun calculator, or a diode across the coil.
P.S. If the object to be magnetized needs more than 1.5T to 2T
then you can't use steel so it gets difficult,
otherwise it's just (Amps)x(Turns) vs. (airgap length)x(Flux density).
