  • Guests: 39
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Quick and dirty turns counter
Fri Aug 20 2010, 07:54PM Print
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
Just got one of these Link2 (although probably available elsewhere) The nice thing about it is that it has a target function that sounds an alarm when a certain number of steps (turns) has been reached. Simply open it up and remove the hair spring on the magnet arm then put it back together and fit it to your former with tape/blu tack etc. start winding and when the number of turns you set has been reached it beeps.
Martin.
Adam Munich
Fri Aug 20 2010, 09:06PM
Very very clever.
Jiffycoil
Fri Aug 20 2010, 09:23PM
Jiffycoil Registered Member #2524 Joined: Wed Dec 09 2009, 06:29AM
I need a counter for my winder. Great idea.
Fri Aug 20 2010, 09:31PM
or use a tape counter removed from a scrap tape deck..
these are obtainable at car boot sales, or flea markets.
plus they usually have a manual reset function and work without applied electrical power unlike digital counters..
wink
-A
"Bother" said Pooh, as he realised the resolution on his video glasses sucked...
Sat Aug 21 2010, 11:35AM
Conundrum wrote ...
That is another way yes although they have disadvantages. Most I've seen only go up to three digits (pedometer has 5), the numbers are quite small and you have to keep checking it (no big deal admittedly) and you have to rig up a 1:1 pulley between you former and the counter whereas this just sticks straight onto the former. As for power, the pedometer comes with a watch battery, never turns off (so doesn't lose the count if you take a break) and I suspect the battery will last for years. If you want a zero cost option then a tape counter is probably the way to go though. I suspect old style cassette decks are probably getting hard to find even at car boot sales these days?
Martin.
Sat Aug 21 2010, 09:03PM
Jiffycoil wrote ...
Bear in mind it probably won't count fast enough for any sort of motorised/high speed winder but will be fine for most hand winding.
Martin.
Fabio
Tue Aug 24 2010, 04:27PM
Fabio Registered Member #122 Joined: Fri Feb 10 2006, 12:55PM
even a cheap pocket calculator can do the job.
just solder 2 wires in parallel of "=" switch and type "0+1".
Every time the "=" switch is pressed or the two wires are connected togheter the count will be incremented by one; this system can also offer some extra math feature, for example this system can measure the total lenght of the wire instead of the number of turns by inserting "0+(D * 3,14)" where D is the diameter of the coilform
Ciao!
Fabio.
Bored Chemist
Wed Aug 25 2010, 06:59PM
I have one of those connected to a geiger counter.
radiotech
Wed Aug 25 2010, 08:28PM
Here's an Archer 221 module, sold for about $6. at RadioShack. Shown hooked to a stop and srtart button-runs on a AA cell. Also is a two-speed hand wind a 5 inch wide bobbin. part of a set of 3 which includes spool horse and a 12 inch winder with layer server.[edit] pics follows
radiotech
Wed Aug 25 2010, 08:38PM
Winder vernier counter- inner 0-100 outer 0-5000
1282768688 2463 FT94908 Archer Counter
1282768688 2463 FT94908 Handwin
