  • Guests: 37
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
AVEN digital microscope
radiotech
Thu Aug 19 2010, 04:52PM Print
The local branch of Active Electronics has Aven Mighty Scope and the accessory stand on sale for a while. This is to be used on a workbench to gather info on projects/repairs etc. Previously a Canon
handycam on a tripod was used because the zoom allowed views of details down to about 1 CM. as well as larger shots. The Aven is a 10X-200X USB scope, but doesnt allow wide shots. Has anyone used this or one similar at a reasonable price. About $200.
Nicko
Thu Aug 19 2010, 07:06PM
These, or very similar variants, have been on eBay for the last year or so.
I bought one that looks almost identical, minus the nice stand, for about USD 50.
Only real problem is the very small depth of field. Here is a snapshot from the one I have:
1282244667 1334 FT94816 Picture 002
see Link2 for an example.
I use it mainly to check my SMT soldering for flaws... It can see between pins of TSOPs etc., which I certainly cannot (unassisted...).
Cheers
Thu Aug 19 2010, 07:52PM
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
I got one of these (only really useful to UK buyers)
You need to be careful to check the specs. when buying digital microscopes, many are only VGA quality and pretty rubbish. I already posted a link elsewhere to a 100TQFP adapter I made Link2 all the pictures were taken with the above microscope. I use a retort stand to hold it Link2
Martin.
Bjørn
Thu Aug 19 2010, 08:17PM
All the webcams I have taken apart could taken shots like that by adjusting the focus so it can get really close. I have added a Nikon F mount to one, then I can use for example a 50 mm f/1.8 lens with manual aperture to get shots like that from a significant distance, or a cheap 70-300 mm zoom to get close ups from the other side of a room. It will not get the enlargement of a proper microscope but I can get much much closer than in that picture.
As Martin King points out, most of the ones you buy are bad quality and that is because they are very cheap webcams/CCTV cameras with the focus adjusted.
Thu Aug 19 2010, 09:59PM
The sales literature makes no mention of numerical aperture, which alone determines the axial and horizontal resolution of the instrument.
There are several different methods of calculating the depth of focus, but all take account of wavelength, refractive indices of the media, numerical aperture, and so on, and all produce results measured in microns.
The depth of focus limitation can be largely overcome using software like Helicon Focus, which allows an incremental stack of in-focus 'slices' to be amalgamated into a single in-focus image, producing remarkable images undreampt of 20 years ago.
This gadget might well be useful for some quality control applications, or to fill a child's Christmas stocking, but, as always, it is the application that determines the suitability of an instrument for any particular purpose.
radiotech
Fri Aug 20 2010, 04:04AM
Thank you for input. The IEEE Spectrum mag had an article on making a microscope out of a webcam last month. Link2
But time is an issue and the Aven unit might be used for an upcoming demo simply because it can throw up an image on a laptop. Aven has magnifiers that range in to the thousands of dollars so I have no illusions here about quality.
teravolt
Fri Aug 20 2010, 04:48PM
hi radiotech, I found this one that I am considering witch is wireless for a decent price.
