  • Guests: 33
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
IR Laser ZnSe vs KBr optics
Carbon_Rod
Sat Aug 14 2010, 07:03AM Print
There are some rather interesting anecdotal opinions on ZnSe collimation and focus lenses for CO2 cutter heads.
I was curious if anyone has ever successfully tried to use something else (like KBr) for a lens in over 50W/CM^2 power 800-1160nm range.
i.e. how long can one expect it to survive compared to ZnSe parts.
Any optics surplus advice would also be welcome wink
Cheers,
Sat Aug 14 2010, 05:45PM
Registered Member #2372 Joined:
The wavelength range you are interested in is basically visible so regular glass optics will work, ZnSn is usually for wavelengths around 10um, it doest really transmit below 2um. Also, that power level seems pretty low, pulsed laser systems are easily over 1 GW/cm^2 in intensity and they use glass lenses all the time for that wavelength range.
Carbon_Rod
Sun Aug 15 2010, 03:50AM
The Fused Silica popped at that range, but perhaps it was contaminants.
Note untreated (no AR coat) ZnSe can easily pass 0.7um to 12um, and is indeed usually less efficient.
Thanks though, I will likely try another Silica lens or an Off-axis parabolic mirror since they are relatively inexpensive and more efficient. Although, I'm not really too concerned about small chromatic aberrations given you are correct in pointing out that the mentioned value is an unfocused CW output. wink
Cheers,
Mon Aug 16 2010, 03:39PM
When you say it popped, what do you mean? Did the coating get damaged or the optic itself crack?
The most likely cause was contamination on the lens, a fingerprint or even some smoke on an optic will quickly destroy it when exposed to high power densities.
The ZnSe would probably be fine, but as was noted normal BK7 would be just as good if not better. Silica is actually inferior to BK7 as long wavelenghts, but at 1100nm it should be ok as long as the AR still works at that wavelength.
Carbon_Rod
Tue Aug 17 2010, 06:53AM
These things tend to split apart too quickly to determine what happened.
For this lens 6% absorption at 50W/cm^2 should only have 3W/cm^2 dissipation max
(and it will be higher for ZnSe.)
I may try BK7 as it looks like it will run a little cooler too.
Cheers,
