  • Guests: 43
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
power control
Thu Aug 12 2010, 12:52PM Print
Right now I manually control the flow of power to a unit using a variac. I dial it up; I dial it down. The output is rectified and smoothed for a DC output. What is my simplest solution for controlling power flow using electronics such that once I dial in a power setting with a potentiometer, for example, the circuit will slowly increase the power until my desired level is achieved? This would also allow me to cut the power off if needed.
Would a buck converter be reasonable?
radiotech
Thu Aug 12 2010, 06:30PM
Replace the rectifiers with SCR's. The firing angle will control the effective DC output voltage that the filters charge to for a given load.The firing angle controller can be a process variable, ie 0-5 VDC
= 0- 100% output power, and you can use a setpoint junction to regulate it to a desired voltage/current or power level.
This is how DC motor controllers worked, very well, before VFD's came along.
Thu Aug 12 2010, 06:54PM
If you do this you should include at least a small inductor in series with the line.
Goodchild
Thu Aug 12 2010, 08:12PM
Be careful when using SCR chopping supply as if you are driving an inductive load (such as a tesla coil) the power factor will be horrible, unless you are at full power.
A buck converter would be better in my mind as you can scale up and down the power and maintain a reasonable power factor no matter what level you have it set at.
lightlinked
Thu Aug 12 2010, 08:22PM
lightlinked Registered Member #2087 Joined: Tue Apr 21 2009, 08:32AM
you could build a big active PFC converter, over in tesla coil land they have been making some big ones
Fri Aug 13 2010, 12:30AM
The buck converter looks easy enough to build. I need one that can handle 10kw (240vac x 40A). Would an IGBT of a sufficient rating work for the switch? How do I determine the proper inductance? Do I have to feed DC into it, or can I input a rectified signal?
