  • Guests: 57
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Discharging a high voltage capacitor?
Plasmaarc452
Thu Aug 12 2010, 05:09AM Print
Plasmaarc452 Registered Member #1394 Joined: Sun Mar 16 2008, 06:18PM
So I am designing a triple stage (1kj or less) coilgun for a school competition and this time I am set on doing it right and safely. My previous experiments with large capacitors showed that discharging with a screw driver is not safe, its scary, and very ghetto This is why I would like to implement a way to discharge the capacitors without touching them. It HAS to be digitally controlled no mechanical switches. I plan on being able to click a button on my computer screen and have the capacitors start discharging.
Right now I am in need of a little input on how to go about this. My best idea/plan is to use an scr to switch the three banks into a 5 to 10 watt resistor. The resistor would then dissipate the energy as heat discharging the banks in a minute or so.
Will that setup even work? I am trying to learn as much as possible here so if anyone out there has done this before could you please post some info anything will help.
Is there a better way to discharge the energy?
radiotech
Thu Aug 12 2010, 06:09AM
What is the voltage of the capacitors you wish to discharge? There are two ways to commutate SCR's, one is with a gate pulse, the other way is to apply a high enough voltage across the anode and cathode. So your SCR's must be rated at a margin above their off-state breakover voltage. Also, a SCR can be discommutated by applying a reverse current across the anode and cathode when it has fired. Typically this is done by discharging a capacitor through the A-K circuit. Not a happy thought in a maze of resistors and capacitors
being sequentally switched.
For life and limb I wouldn't trust a SCR crowbar.
Plasmaarc452
Thu Aug 12 2010, 06:34AM
The capacitor bank will be at 500v in banks of 3 capacitors (9 caps in total making 1kj).
I am confused as to what you are saying about using an scr like this. WIll it work if I just want to apply a gate pulse and let the energy drain? Once it is in the process of draining it doesn't have to be stopped it can go until the capacitors are discharged.
This is purely a safety feature that just has to work, so if the scr is not a good option do you have any other suggestions on how I could go about doing it?
Thu Aug 12 2010, 07:23AM
A good method if discharging Large capacitor banks quickly is to use incandescent light bulbs. Your bank is 500v, so if your light bulbs are 110v then you will need 5 in series.
radiotech
Thu Aug 12 2010, 07:26AM
Once you fire the SCR, it will discharge the capacitors through the resistors you select. As the voltage lowers, the current lowers until it falls below the minimun needed to maintain commutation. The capacitor will have a residual charge. This presumes the scr did in fact fire. (How would the digital safety system know that ?)
If you use 4500ufd total in 3 banks of 1500 ufd, and connect a bleeder resisistor of 10,000 ohms, or 3- 30,000 ohm (one for each bank) it will discharge the caps to a safe level in about 2 minutes.
Left on permanently, It will subtract 0.05 amps from the banks or about 8 watts from each bank, at the time of firing. (about 2.5 % of the energy) Bleeder resistors have to be permanently connected, not switched, if safety is involved.
Plasmaarc452
Thu Aug 12 2010, 01:57PM
Yea I came across bleeder resistors in a video yesterday and thought about using them. That seems like the best idea, I am not concerned about losing 2.5% of the energy to implement such a safety feature.
The entire coilgun is digital I didn't really make that clear above. Everything from the power supply, charger, scr firing, optical detection system, and voltage measuring will be done via a large master board and many smaller slave boards. Each of these boards is fully accessible via usb allowing a laptop computer to essentially control the gun using my software. As far as I know no one has attempted to build something that is controlled like it will be.
Antonio
Thu Aug 12 2010, 11:07PM
Shield everything very carefully, or at each "bang" all your digital circuitry will go nuts...
Plasmaarc452
Fri Aug 13 2010, 02:50AM
I had planned to use protections against back emf on the coils to protect the scr's. The circuitry connected to anything involving high voltage would be optically isolated to prevent any weird problems coming back.
Any suggestions on that note either? Anything else for protection I could put in?
radiotech
Fri Aug 13 2010, 04:09AM
You have described a SCADA system.
SCADA systems are telemeter/control used for everything in industry
but the controlled end has to have failsafe routines to drop back to local control if the supervisory link is corrupted.
Plasmaarc452
Fri Aug 13 2010, 01:57PM
Thats what makes it so interesting, there aren't set plans from somebody else on how to do it! Making the coilgun is the easy part but adding the digital circuitry safely is another matter.
I am making special points about how it is controlled when my project is complete. I didn't know its actual name SCADA I always said industrial control technology but I will include that now in my final report on it.
For anyone out there that knows digital circuitry are there ANY MORE protections I could put in! Please the last thing I want is to fry my board over something that could have been prevented.
