  • Guests: 48
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Raising input voltage of a ZVS driver
HazzWold 1993
Sat Jul 31 2010, 12:47AM Print
On the Vladimiro Mazzilli flyback driver what components need be changed in order to allow for higher input voltage, currently Ive run mine up to 50VDC from a rewound MOT smoothed but no current limiting, and nothing on the driver or MOT gets hot (only the wimpy ac flybacks i keep melting) and i have since added a 75DC tap point on my MOT supply and don't really know if my driver will handle it. i have seen a video on YouTube where a guy put another 470ohm resistor in series with the ones on the circuit like one on each, Would that be sufficient ?
the components im using are as follows
1x 680nf PP axial leads capacitor
2x 5watt 15v zeners
2x IRFP250's
2x 10k 2 watt resistors
2x 470ohm 2 watt resistors
1x inverter MO inductor core rewound with 30 turns of wire from a MOT primary coil
2x ultrafast 400v 30amp diodes, 30ns recovery
Matt Edwards
Fri Aug 13 2010, 12:13AM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Honestly, I am not sure that you will find a flyback that will survive more than 40v vary long... Even if dipped in oil... But I could be mistaken.
Someone correct me here if I am wrong! I would like to know as well.
teravolt
Fri Aug 13 2010, 04:22AM
add more primary capacitance beween 1.5uf to 3uf or more at a VCC around 40v. What gauge are you using on your primary and what type of caps are you useing. Cirtan flybacks are only going to be able to put out so much voltage. bigger fly = bigger spark also more flies of the same type can be phased in or out for voltage increase or current increase
HazzWold 1993
Sat Aug 14 2010, 01:13AM
Im using a 680nf 600v PP capacitor with axial leads
and a 5+5 turn primary of wire from a mains plug cord, not sure of the gauge but fairly big
