  • Guests: 60
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
How do you distinguish Aluminium and Beryllium Oxides ceramics?
IntraWinding
Wed Aug 11 2010, 11:23PM Print
I have quite a lot of ceramic insulators but I've always assumed they were Aluminium Oxide.
How do you easily distinguish Aluminium and Beryllium Oxides ceramics?
Thu Aug 12 2010, 12:07AM
AFAIK due to it's toxicity Beryllium is only used inside packages
between silicon and metal normally.
I expect that any ceramic tile will not be Beryllium.
I hope my assumption is correct.
Adam Munich
Thu Aug 12 2010, 01:32AM
Beryllium ceramics are fantastic heat conductors. Much better than alumina ones.
radiotech
Thu Aug 12 2010, 02:45AM
How about looking at the density of alumina and beryllia
Alumina is 4/3 heavier. There used to be a hook on the end of a triple beam balance to hang stuff on, like a string, so you could weigh irregular objects in water and shout Eureka - I have found it !
Dont try this with Na or K.
IntraWinding
Thu Aug 12 2010, 06:27AM
Sulaiman wrote ...
That's what I thought until I read the third post in this recent thread Link2
Look at its photo Link2, a Heathkit leaflet warning that the transistor mounting insulator is Beryllium Oxide! First I've heard of it outside of semiconductor packages, apart from Argon Ion lasers!
I know I could use lots of complicated methods to distinguish it from Aluminium Oxide, but is there a quick and easy method?
Thu Aug 12 2010, 08:34AM
I think I have here 8 TO-3 beryllium oxide transistor insulating pads, they are around 3mm thick. I can't imagine anything else as thick could conduct the heat adequately.
Adam Munich
Thu Aug 12 2010, 01:57PM
Magnetrons typically are made with beryllium oxide ceramics.
IntraWinding
Thu Aug 12 2010, 03:57PM
Grenadier wrote ...
Are you sure this is true of domestic microwave oven magnetrons as I would expect them to avoid using highly toxic materials in a domestic product, but to mark it clearly as hazardous if they do, and the few microwave ovens I've stripped had no warnings.
Also, I notice a remark referred to elsewhere in this forum that the 'pink' ceramic sometimes seen in magnetrons is Beryllium Dioxide according to Wikipedia is out of date as Wikipedia didn't mention this when I checked the link today.
Adam Munich
Thu Aug 12 2010, 04:07PM
IntraWinding wrote ...
Also, I notice a remark referred to elsewhere in this forum that the 'pink' ceramic sometimes seen in magnetrons is Beryllium Dioxide.
This.
IntraWinding
Dr. Kilovolt wrote ...
I have some similarly thick ceramic insulators for TO-220 packages which I stripped out of old equipment.
I assumed they where Aluminium Oxide used as reliable high voltage insulators with sufficient thermal conductivity for the job.
Are they likely to be Beryllium Oxide even for a more recent transistor package style and no warning given?
And how can I tell in practice?
