  • Guests: 55
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
high power electromagnet >3kW
Reaching
Fri May 12 2006, 01:40PM Print
within the next weeks i want to build a huge electromagnet for various experiments. with a 10mm Bore inside(10mm aluminium, 8mm inside) and an outside diameter of approx 100mm. to get a high density i wanted to use the smallest wire possible for around 16A at 230Volts(0,5mm)Dc. The coil will be watercooled to allow a few minutes of runtime.
do you think it is possible or am i totally wrong'?
is anyone expierienced in building higher power electromagnets?maybe someone is interested to make a femm analysis, im not expierienced in Femm.-
Marko
Fri May 12 2006, 03:35PM
For DC you can simply find biggest piece of iron around for a core.
Windings will also give only DC resistance so you can put a lot of current into the magnet ( depending how much power can you draw from it)
I think Tesladownunder owns one such a big magnet here. smile
Fri May 12 2006, 06:31PM
I haven't built such a device,
but from other experience I suspect that the 'best' configuration is a 'brooks coil'
Just a name for a multi-layer coil giving maximum inductance/resistance.
This is for an air-core inductor.
Probably the best places for ideas are
NMR electromagnet technology
or
the home of magnetically levitated frogs
Simon Barsinister
Fri May 12 2006, 10:13PM
Simon Barsinister Registered Member #116 Joined: Fri Feb 10 2006, 03:19AM
Wind it with the core winding 1 wire size smaller than the outer one. That is how they make the really big ones. Think amp-turns and losses. It's a lot more wire per turn at the outer parts.
Rich
Reaching
Sat May 13 2006, 07:44PM
yeah, i wanted to build one of these magnets , called bitter magnets , flying frogs etc. but i dont have the equipment to construct these copper plates etc. so i thought about a simple "normal" coil with a 10mm Bore inside so i can put pieces inside and make my experiments with it.
i want the highest magnetic field possible with around 3,6kW of power. i have the equipment to build a dc powersupply with around 3volts and 1kA Dc that would give me the highest magnetic field possible, but is it good enough or powerful enough for my needs? (around 1-2Tesla, hopefully)or should i go with more voltage and less current ,btw whats the best configuration ,voltage,current for a high field strenght electro magnet?
,thanks for the answers
Sat May 13 2006, 09:29PM
If you are aiming for 1 to 2 T
then use transformer lamination steel for 1.8 T saturation flux density
the iron core will reduce required amp.turns for a given flux density.
Use as short an airgap as possible.
Above this flux density iron/steel saturates so is no help - air core required.
'square' wire or foil will give more amps/square-meter in the coil
giving more Tesla/amp.
I^2.R losses / heat will be the limitation for an air core magnet
so
1)
The optimum power supply is Vdc = Idc x Rcoil
2)
Short ON times with longer cooling-down OFF times will give highest flux density
so do you need a continuous magnetic field?
McFluffin
Sun May 14 2006, 12:23PM
McFluffin Registered Member #119 Joined: Fri Feb 10 2006, 06:26AM
I think most of these are pulsed power magnets, but I have a book called "The Internation Symposium of Magnet Technology." An older book(1965), but its on building high power magnets for particle accelerators. Maybe I could post the table of contents and, if a specific paper interested you, I could scan it and send you a PDF.
OScoder
Sun May 14 2006, 04:05PM
OScoder Registered Member #304 Joined: Sat Mar 11 2006, 02:19PM
one possible problem I saw:
Where are you going to get the power from?
Sun May 14 2006, 06:53PM
Using dc
the stored magnetic energy will be massive,
so expect a humungous 'flyback' spike on switch-off
and use a suitable 'freewheel' diode to 'catch' the kickback.
P.S. 220 Vac full-wave rectified gives about 300 Vdc
300 V @ 10 Adc would require the same weight of wire as 3V @ 1 kAdc
for the same magnetic flux and volume
but needs 10x less cross-sectional area wire,
easier to find and wind,
And easier design of power supply
and easier to find 10 A diode than 1 kA diode.
Hazmatt_(The Underdog)
Tue May 16 2006, 02:01AM
look at this badboy Link2
Super cool!
Probably an EMP test fixture, what else could it be anyways.
Now all you need are many large cap banks and switchgear, say 100 banks, each pulsed into that fixture and you got it!
heheheh.
