  • Guests: 51
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
TEA nitrogen laser
G^3
Sun Aug 08 2010, 09:17PM Print
G^3 Registered Member #97 Joined: Thu Feb 09 2006, 05:40PM
I built a TEA laser that is nearly a copy of the http://www.sparkbangbuzz.com/tealaser/tealaser7.htm, but with 3 layers of 1 mil plastic painters drop cloth for a dielectric. I tried both the his "against the wall" method and the "double inverted V" (two pieces of 1/8 inch aluminum angle iron on their edges.) I found that the "double inverted V" is simple and easy. After I smoothed the sharp ends left from cutting the aluminum it took me about 30 seconds to get it to work.
My questions is now what?
What can I do with a nitrogen laser?
Adam Munich
Sun Aug 08 2010, 10:19PM
Pump a dye laser. Link2
