  • Guests: 52
My 3 stage coilgun
teslasapprentice
Mon Aug 02 2010, 09:30PM Print
teslasapprentice Registered Member #2996 Joined: Tue Jul 13 2010, 12:23PM
Okay, so like i was building this really nice 3 stage coilgun and it was all going well, but my contact switches dont work if i go above 100 volts :/ so i was wondering if anyone knew any circuits that when i press the fireing button it turns on a timer that then turns on a relay after a set amout of time Thanks in advance!!!!!
Adam Munich
Tue Aug 03 2010, 02:02AM
genious 7
Tue Aug 03 2010, 10:23PM
genious 7 Registered Member #2887 Joined: Sat May 29 2010, 11:10PM
I'd recommend you to use SCR instead of a relay, since they are faster and will yield you a better timing and a greater precision. Use the 555 monostable for the delays.
