  • Guests: 68
Flyback Transformers
Xplorer
Fri Jul 30 2010, 07:48AM Print
Xplorer Registered Member #2416 Joined: Sun Oct 04 2009, 04:23AM
Hey guys,
I salvaged this flyback from an old TV and it has this extra transformer looking thing attached to it. Do any of you know what it is and whether or not it should be left on? Is it the HV diode?
DSC09307
Also do you have any links to a good schematics? I've built simple transistor based circuits before but I'm after some hotter sparks now.
Thanks!
-Tony
Fri Jul 30 2010, 08:18AM
thats unique, i think there are one or more diodes and atleast one cap in that extra moulded case, it coud be for pulse/waveform shaping, or a traditional CW multiplier, i dont know what you should do. i gave up on figuring out other "special" devices. i make my own transformers from the ferrite up, now largley becuase its so hard to figure out schematics and specs of salvaged stuff.
HVgeek
Fri Jul 30 2010, 08:43AM
HVgeek Registered Member #2998 Joined: Tue Jul 13 2010, 08:34PM
That's odd... Never seen that before. Unless there are any additional leads to it I'd say it's a straight forward diode. If there are more hookup points than the big one on the top it it's probably a CW multiplier.
Amyhow, I don't think it's of any good use, so just crack it open and tell us what you find inside. That hould dispel the mystery. If you are gentle you might even keep the component functioning; the plastic is only structural.
Fri Jul 30 2010, 12:39PM
HVgeek wrote ...
Somehow I don't think I would do that...
Myke
Fri Jul 30 2010, 03:40PM
I doubt it is a CW multiplier since those require AC to function. You can see that the flyback has an internal diode because of the rod shape on the side of it. It might be a high voltage divider for screen and focus supplies? They might have made it the way they did to decrease the likelihood of surface tracking. I'm not sure though.
radiotech
Fri Jul 30 2010, 05:45PM
It is a high voltage multiplier with focus divider. here are the typical schematics from NTE 11.
1280511943 2463 FT93525 Scan0004
edit: try going to the NTE site and entering the numbers on it.
Fri Jul 30 2010, 06:14PM
Some crt have an external eht capacitor as well as the internal (wall) capacitance,
I think it's just an eht capacitor.
Fri Jul 30 2010, 07:14PM
I have seen different kinds of potted stuff, such as rear projection screen TV's have a box like that which is a HV splitter. The input is connected to an internal capacitor (3nf 30kv is what you will usually find), and there are 3 outputs, each connected with their own resistor.
I do not think it is a multiplier... Like Myke said, that is almost surely a DC LOPT.
My guess is that yours is just cap block tongue. Maybe a resistor too.
Fri Jul 30 2010, 07:26PM
I'm sure radiotech is right, and the mystery object is a voltage multiplier module.
I looked in my junk pile to see if I could find one like it. I couldn't, but found seven other types in five minutes of rummaging, and could have found more if I'd put some effort into it. Some are doublers for black and white CRTs, but most are the triplers needed for colour. You can even see the C&W
zigzag in the bright blue one at left of centre.
1280517364 543 FT0 Tv Eht Multipliers 002 Small
These modules were the intermediate technology between EHT diode sticks like these, which you could unplug and replace when they failed, and the completely encapsulated diode split LOPT, which we all know and love today. smile
1280517387 543 FT0 Tv Eht Multipliers 003 Small
Fri Jul 30 2010, 08:55PM
Proud Mary wrote ...
I just geeked myself.
