  • Guests: 142
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Is welding copper to aluminum acceptable for thermal dissipation applications.
Mon Jul 26 2010, 09:59PM Print
I am wondering if it is a good idea to make a spot welder with some large wire and an old 720 watt NST core, which i could probably run like 2kw through continuous for spot welding copper tubing to aluminum.
Also, i have so aluminum sheeting and some misc pieces of alum, would spot welding aluminum sheets upright onto a block of aluminum make a usable heatsink? Some PC heatsinks are not extruded but made in a way something similar to this, but i don't know about the spot welding.
Mike
Mon Jul 26 2010, 11:46PM
I suppose it would work but you would need to weld quite a few sheets and if you only weld 'spots' and not a continuous weld the heat won't transfer very well to the fins. Most heatsinks I see are machined with a CNC anyways.
Tue Jul 27 2010, 12:01AM
The mechanical and thermal joint between fin and base plate is critical.
Most heatsinks I see are extruded, skived Link2, or otherwise formed by plastic deformation of a workpiece.
IMHO, CNC machining is too slow, expensive, and wasteful of material to be the primary fab method in most production heatsinks. Even machining with special setups (e.g. using a stack of slitting saws and spacers) is the exception rather than the rule.
Welding Cu to Al is impossible by definition, at least in the USA, where I was taught that "weld" implies fusion of the base metal, and mingling of the melted portions of parts to be joined.
Mike
Tue Jul 27 2010, 03:06AM
Ah you are probably right there klugesmith, I was just implying they are machined from a solid piece of metal typically. Though I do wonder about those very large thick fins, they wouldn't also be skived would they?
Tue Jul 27 2010, 03:45AM
You can technically weld copper to aluminum but it isn't really an option in your case. Interesting process none the less. Link2
Mike
Tue Jul 27 2010, 04:28AM
hmm, while watching that video I came across a video from muggyweld.com that claims a rod that can weld any metal to any other metal (exception of magnesium and cast iron) they show in the video a piece of aluminum welding to brass very easily and nicely, Link2
Is this for real? here is the rod Link2
Maybe this is very old news and im under a rock in the welding world :)
Electroholic
Tue Jul 27 2010, 09:49AM
I know the type of heatsink you are talking about, they are not spot welded, but rather "glued" with low thermal resistance silicone.
UltraMagnus
Tue Jul 27 2010, 04:20PM
UltraMagnus Registered Member #2875 Joined: Mon May 24 2010, 08:28AM
Railway tracks are sometimes welded using thermite, it might be possible to user copper (II) oxide - aluminium thermite to weld them together
Mike
Tue Jul 27 2010, 06:08PM
Somehow I can't imagine thermite being used very easily to weld aluminum and copper on a heatsink considering how small that is and how hot thermite gets. Seems like a lot of work, might as well by some used huge hsinks.
dmg
Tue Jul 27 2010, 06:28PM
Electroholic wrote ...
I use a method as Electroholic said, particularly right now with my bridge, in my case, its mostly to compact then dissapate, but I figure why not, so I usually just put a layer of thermal grease (or a sil pad) across where the 2 pieces are joining, and use several bolts to tighten everything up very well, usually works okay,
in the picture its two AL heatsinks, but I dont see why this method cant be used for copper and AL, you are not welding anything, and all it takes is some thermal compound and a few bolts.
1280255281 2628 FT93348 Heatsinkattach
