  • Guests: 56
oucivileng (39)
01/27 muller (38)
01/27 Dr. Mario (38)
01/27 Ben Solon (30)
Mot Stack-Current limiting
Micha0_0
Mon Jul 26 2010, 03:00PM Print
Micha0_0 Registered Member #2990 Joined: Mon Jul 12 2010, 11:22AM
hey guys...
I build an 2x motstack an it runs very well (10-15cm. arcs)
I run it on Phase 1 and N from the 400 volt line ,because there is a 16 amp safety device
but the mot stack draws too much current and i´ve to limit it
i know i can use an mot with short circuit secondary in series to the mot stack
but i just have an mot without an secondary winding, so i tested it (in series to the stack) and i just have an 5mm arc (is it too much limited?)
or must the mot have an secondary which is short circuited?
i heard about limiting it with lightbulbes
how is this done ?
just some lightbulbes in series to the mot stack´s primary ?
Sry for my bad english :D
greet micha
dmg
Mon Jul 26 2010, 03:05PM
let me understand better, your feeding a mot 400V?
Micha0_0
Mon Jul 26 2010, 03:14PM
no i just use phase 1 and N so it is 230V an 16 amp instead of the normal 230V line which just has 12 amp
Mon Jul 26 2010, 05:32PM
saw off the "I" part of the core and include a gap while you assemble it back. You can control output current by changing the width of the gap.
Micha0_0
Mon Jul 26 2010, 07:02PM
i´ve found an old ring-core
i wind 104 turns 1,5mm² wire on it
i´ll test it tomorrow,if it works
HVPaul
Mon Jul 26 2010, 08:28PM
HVPaul Registered Member #2321 Joined: Fri Aug 28 2009, 05:13PM
Would current limiting using a 250 watt incandescent bulb in series be effective?
I'd imagine you could stack them in parallel to allow more current.
Micha0_0
Mon Jul 26 2010, 08:35PM
i´ll test it with some 100W bulbes in series or paralell
radiotech
Mon Jul 26 2010, 08:53PM
Just make sure the lightbulbs are the same voltage as the system voltage, ie 230 volts. They can pop violently if overvolted.
Micha0_0
Mon Jul 26 2010, 09:13PM
im from austria ...so everything is rated to 230volts ;)
is it more limited when i put some bulbs in series or some in paralell
(and in series to the stack)
cedric
Tue Jul 27 2010, 08:13AM
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
what about some tl ballast in parallel or a hdi one ?
