  • Guests: 72
muller (38)
Dr. Mario (38)
Ben Solon (30)
01/27 muller (38)
01/27 Dr. Mario (38)
01/27 Ben Solon (30)
on-line smp
cedric
Wed Jul 21 2010, 11:59AM Print
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
hello ,I am new on this forum ,
I am working for a company to build hi voltage ns pulse power supply for lab use (a dream!)
Aldo I only have my limited experience as hobbyist ,I now have to build a 1 KW 15 kv power supply as a primary supply for a pulse generator
I already build a half bridge power supply ,directly power on the main ,using a gate drive transformer as a galvanic isolation in between the control board and the main ,I could get up to 400 w of power witch is pretty good ,with a relatively simple layout,but 400 w is not enough and I need to have control toward the currant out put (the gate drive transformer allow only 50/100 duty cycle) ,do any body know a lay out for a full bridge pwm control witch could be feed from the main with galvanic or opto-electric isolation of the control board?
an other question:
Is there a maximum power to a pwm using only one brick igbt and why is there a consensus is that this type of power supply should not be use above 200 W?
thank you by advance for any answer...
cedric
cedric
Fri Jul 30 2010, 08:16AM
ok ,I reply to my self...
for the second question:
I hook up two mosfet in parallel and plug it on a 24 v 30 A dc source , direct to a fly-back with pwm control and injected up to 30 amp in the fly-back with out braking every thing...that about 600 W !!!
