  • Guests: 30
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Transformer Issue - reading the template
Captoro
Sat Jul 24 2010, 12:27AM Print
Captoro Registered Member #2946 Joined: Mon Jun 28 2010, 09:34PM
Hello,
I am looking for somebody that could tell me what I am interpreting is actually what is going on with the template of my transformer. It is a 9Kv transformer, with two input bolts and two output. One alone on the side and three at the opposite side. It says secondary id 'MID TAP' GND, does this means the bolt alone up front is 4.5KV and the one in the back is 44.5KV. Or is it 9KV up front and 0 at the back ? what is the MID TAP .
And the P.F. power factor, says is 'N' I guess neutral or none ? so it has a power factor correcting capacitor ?
thanks
K
Transformer
Sat Jul 24 2010, 01:11AM
It does appear that it is grounded at the middle, so you get 4.5kv RMS out each of the hv terminals.
The N for power factor is beyond me, but for such a small transformer I wouldn't worry about it.
Sat Jul 24 2010, 09:21AM
N here stands for 'Normal' - meaning a power factor less than 0,9.
