  • Guests: 28
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Capacitor Charging
cduma
Tue Jul 20 2010, 05:17PM Print
My prof assigned some extra credit and the assignment is to find the missing resistance value. The circuit is an RC circuit with a 200uF cap and a 20V source. It charges the capacitor to 12volts in 30 seconds. Where would I start?
Tue Jul 20 2010, 06:31PM
It's clear that -you- started by asking for help. For what kind of career are you studying RC circuits?
I would start by getting the formula for volts vs. seconds in "an RC circuit with a 200uF cap and a 20V source." Presumably that's regular subject material in your class and your textbook. Step 2: solve for R.
radiotech
Tue Jul 20 2010, 08:28PM
Stare at the numbers 12 and 20 and realize that your prof wants you do some calculator work beyond simple arithmetic.
cduma
Tue Jul 20 2010, 09:30PM
Its not for a career in RC circuits, its just part of the class work. I looked through the current chapter and the next and all I found was the basic 63.2% per T. The value of R is somewhere near 150K which gives a voltage of 12.68V at the first 30 seconds.
big5824
Tue Jul 20 2010, 09:42PM
search for "equation for capacitor discharging", and also remember it takes the same time to charge a capacitor from 0 to say 20% as it does to discharge from 100% to 80%
hboy007
Wed Jul 21 2010, 12:11AM
hint: solve the differential equation associated with this problem (why might the unit of charge be 1C= 1As?). You might as well waste the exercise and find the solution on the internet.
hint 2: Integration constants are not necessarily zero wink
radiotech
Wed Jul 21 2010, 02:52AM
another hint: perhaps log base 2 is used:.
