  • Guests: 45
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Make your own laser spectrometer in 3 minutes
Bjørn
Tue Jul 13 2010, 04:58AM Print
Print this picture, cut a piece out of an old CD (DVD will not work), apply tape, done!
This is how the positions of the markings are calculated:
angle = Asin(wavelength / lineSpacing)
scalePosition = baseline * Tan(angle)
If you know the angle of deflection and want to find the wavelength you use:
wavelength = lineSpacing * sin(angle)
The line spacing of a CD is 1.6 um and DVD is 0.74 um. It is possible to find discs with non standard line spacing but they are not very common. DVDs can be double layer and cause problems.
It is possible to use this method to determine the wavelength and spectrum of other light sources than lasers but because of the low efficiency it is difficult unless you use a camera and a fairly long exposure. Make a narrow vertical slit in the middle of the laser window using black tape. Adjust the distance between the light source and the slit to find a compromise between resolution of the spectrum and brightness.
The example shows a mystery "UV" LED that seems to be about 410 nm.
1278997120 27 FT0 Laserspectrometer
1278997120 27 FT0 Mysteryuv410
3l3ctrici7y
Tue Jul 13 2010, 06:55AM
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
That's awesome! Thanks for the info.
It reminds me of the time my chemistry professor in college handed out diffraction grating slides, then used an HV supply to excite various gasses and we could use the slides to directly view the spectra lines.
Avi
Tue Jul 13 2010, 09:44AM
If you can not print it at 300DPI, resize it such that the image turns out 15.26x12.72cm on paper
Tue Jul 13 2010, 11:09PM
neat bjorn smile
apparently another trick is to use two new razor blades with a microscopic gap between them, this gives highly consistent results..
was also looking into modding a cheap webcam from an aspire one for this purpose.
-A
3l3ctrici7y
Wed Jul 14 2010, 04:49AM
schlieren photography
aonomus
Wed Jul 14 2010, 09:45PM
Will this function with CD-R's, or does it have to be injection molded? I suspect it has to be injection molded due to the lines being physically part of the plastic acting like a diffraction grating vs the amorphous phase change material in a blank CD-R.
IntraWinding
Thu Jul 15 2010, 01:00AM
The coating comes off a CD-R quite easily (or used to a few years ago) with a bit of bending and leaves the clear plastic disk as a good transmission grating due to some sort of guide track impressed on the plastic during manufacture. Some sellers used to use a pair of uncoated discs (with the diffraction pattern) as protection at each end of a cheap shrink wrapped stack of 100 discs. Don't touch the patterned surface as finger marks are enough to ruin the effect and diffraction gratings are too fragile to easily clean.
Bjørn
Thu Jul 15 2010, 06:53AM
Yes, CD-Rs have a guide line for the laser to follow while writing to the disc. It is also much easier to get the reflective coating off CD-Rs, the last time I removed the coating from a moulded CD I had to boil it.
Here is the spectrum I got from a white LED, it is overexposed but it is easy to see that the LED under the phosphor is about 450 nm.
1279176814 27 FT92614 Spectrumwhiteled2
Bjørn
Tue Jul 20 2010, 12:17PM
After testing most of the different CDs I got I found out that modern CDs are not very reliable when it comes to track pitch. Most of my CD-Rs have tracks closer than 1.6 um. On some it makes a difference between reflection and transmission, others change depending on what side is used.
So for a reliable result calibration is required.
