  • Guests: 45
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
A "totem pole switch" I got problem with basic electronics understanding.
cavemen
Fri Jul 09 2010, 02:57AM Print
cavemen Registered Member #2008 Joined: Tue Mar 03 2009, 05:11AM
We have anomaliously high temperature outside and our air conditioner broke.
It is too hot for me to think.
A tiny IC can drive POWERFUL devices at high frequencies with a Totem Pole switch.
That is when two transistors drive one powerful mosfet, one turns it on, other turns it off.
One transistor is PNP one is NPN and they have to be a complimentary pair. I found several darlington transistors to give me an ability to drive my moasfet with 3.3V push-pull or 5V. (Everything is on paper.)
I am developing a universal circuit to meet all my needs. (I will publish it when it works.)
I got a problem:
I want to bring that MOSFET voltage drop almost to 0 when it is on and get about 9V at the gate of the MOSFET. For some reason I can never get that high.
For some dumb reason it doesn't happen and I don't understand what variable I got to change. Darlingtons have a HFE of 12000 each.
Would this circuit work with a pair of complementary FIELD EFFECT TRANSISTORS?
I would like to know the math because I do math in excel as I design the circuit.
Thank you.
V.T.
circuit: Link2
cavemen
Fri Jul 09 2010, 03:09AM
The multisim 11 circuit of the device.
]totem_pole_dalington_switch.zip[/file]
Avi
Fri Jul 09 2010, 07:52AM
cavemen wrote ...
It should not be assumed that everyone has windows and multisim.
A screenshot would suffice.
IntraWinding
Fri Jul 09 2010, 07:54AM
Can you post a picture of your circuit?
Fri Jul 09 2010, 09:43PM
Avi wrote ...
even though i have win and multisim caveman, Avi makes a good point.
i demand a screen cap.
Bjørn
Fri Jul 09 2010, 11:26PM
There is one linked in the very first post.
IntraWinding
Sat Jul 10 2010, 01:25AM
Bjørn wrote ...
Ah, right, I didn't notice that the first time.
Picture of circuit here: Link2
cavemen: It looks like you've got the emitter and collector pins of Q1 reversed.
cavemen
Sat Jul 10 2010, 03:19AM
It makes no difference with the Q1 being upsidedown or right side up.
The voltage still doesn't exceed 9.7.
It looks like it has something to do with 12v and 3.3v causing some reverse - bias at the transistors.
I can calculate the discharge time (RC) of the MOSFET gate and loads, but I cannot understand what happens between the signal source and the darlingtons.
The gate voltage hangs aroung 6.8V
cavemen
Sat Jul 10 2010, 03:38AM
Does the circuit makes the output difference?
Doesn't look like it.
cavemen
Sat Jul 10 2010, 04:55AM
When I short the gate to +12V the MOSFET will open only to 9.8V.
12V exceed the maximum gate voltage rating of the mosfet, thing still ain't opening.
Something wrong with my understanding of the process.
1278737712 2008 FT92322 2version
