  • Guests: 25
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Simple DC to DC boost schematic
Xplorer
Sun Jul 04 2010, 06:47AM Print
Xplorer Registered Member #2416 Joined: Sun Oct 04 2009, 04:23AM
I'm just wondering if anyone has any good links to a simple DC to DC boost driver schematics. I need it to accept an input voltage of about 2.5-5 volts and output 4-6 volts and handle currents of up to an amp. Truth be told I'm building a driver for a 445nm laser diode and I'd like to be able to run it off a single 3.7v battery.
Thanks
-Tony
lightlinked
Sun Jul 04 2010, 10:09AM
lightlinked Registered Member #2087 Joined: Tue Apr 21 2009, 08:32AM
National Semiconductor has pretty good app notes for their range of smps controllers. For a simple boost supply reference there is the minty boost. 3v in 5 v out. Link2 and I think Sparkfun has some simple boards premade. If you want it to also limit the current you could look at some high power LED drivers
Remember that you should implement a low voltage cutoff (3 volts) for li-po/li-ion batteries so they don't get over discharged and die. li-po will be 4.2 v charged so you might need a SEPIC design if you really want 4-6v out from 3-4.2v in.
UltraMagnus
Tue Jul 06 2010, 08:51AM
UltraMagnus Registered Member #2875 Joined: Mon May 24 2010, 08:28AM
I don't know if it is any help, but microchip have a "tips and tricks" document here Link2 that explains how to make a uC controlled boost converter.
