  • Guests: 64
Bauerb2 (36)
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
ZVS Parts
1 2 3 4
HazzWold 1993
Thu Jul 01 2010, 06:56AM Print
Okay, my last thread on this disappeared when the site crashed, so here it is again. A list of Vladimiro Mazzilli ZVS driver parts. Just to ensure they are the right ones.. or that they would at least work as i don't want to spend the money needlessly. so any feedback is appreciated.
1x Inductor -
2x IRFP250 -
2x Zener Diodes -
2x Fast Diodes -
2x 10k 2 watt resistors -
2x 470ohm 2 watt resistors -
1x 680nf capacitor -
smile
quicksilver
Thu Jul 01 2010, 06:33PM
That looks like what I ordered (scavenged) and mine worked: put out a nice thick arc, no thin blue line there.... My second one I wound my own coil and borrowed a meter to test it and it put out about 100+ Uh & I think it worked a bit better. I went a bit stronger on the power MOSFETS & felt better about running higher input.
HazzWold 1993
Fri Jul 02 2010, 01:49AM
What MOSFET's did you end up using? i plan on running this around 50V so i need to keep everything fairly big, and yeah i was thinking of winding my own inductor.. i feel i need to order enough stuff from them in one order to justify the postage though. lol
quicksilver
Fri Jul 02 2010, 05:17PM
I really looked for you but it was pulled from some existing application and I can't read the MOSFET numbers. When I originally pulled them I used a magnifier to find the numbers and they were a bit tougher - marginally higher than 33A 200v as the IRFP250 is.
Since your using MOUSER - it will be pretty easy; just look up "power MOSFETS" and find where the IRFP250 is on a page listing and find a model with greater voltage & current handling capabilities (they have page listing capabilities with "hunting" criteria.).
But realistically 200v & 33a is pretty tough. I think that also the price from MOUSER for the IRFP250 is like $4 and getting even tougher ones is a jump in price. It MAY be a better idea to just buy 4 or 6 of them in case you blow them out by some quirk. But if you think you won't go much higher than 50v & maybe 20a I wouldn't bother.
I have a Lamda power supply (I got real lucky!) that can put out up to 150a and wanted to try using as much as I could and not blow the flyback (came to about 25a and then it started to get VERY hot.)
I encourage you to wind the inductor. Especially if you can find a meter at some electronics store to "test" it in a demonstration (they are really expensive, usually a capacitive and Henry meter are in one unit). If you do actually buy an inductor at a given level (let's say 47uh) then you could go by a very rough estimate of wire size, turns, & size of toroid to give you an approximation of what you have....
HazzWold 1993
Fri Jul 02 2010, 09:50PM
Thank you, that was a very informative and helpful reply
teravolt
Sat Jul 03 2010, 04:50AM
I have used 40n60's and HGTG27N120BN with good performance
HazzWold 1993
Sat Jul 03 2010, 10:08AM
My current list, any input to whether its any good is welcome:
For the 680nf capacitor, will this work? - Link2
For the Fast diodes Link2
For the Zener diodes Link2
For the 470ohm 2 watt resistors Link2
For the 10k 2 watt resistors Link2
For the IRFP250's Link2
Matt Edwards
Sat Jul 03 2010, 01:57PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Here is the parts list from mouser that i purchased.
1. Mosfet's------ IRFP250PBF-------------- 2
2. Zener Diodes------ 1N5349BG--------------- 2
3. FRED Diodes------ HFA15TB60PBF ---------- 2
4. 470 Ohm 2W Resistors------ 282-470-RC----------- 2
5. 10k 2W Resistors------ 282-10K-RC----------- 2
6. 1uf 100v Bipolar Capacitor------ 140-NPAL100V1.0-RC------------ 1
7. 47UH 10.7A Inductor------- 2309-V-RC----------- 1
HazzWold 1993
Sat Jul 03 2010, 09:30PM
Oidium45 wrote ...
Thanks but im not going to use mouser, Farnell would be cheaper
Can anyone tell me if this cap is right? ive had trouble finding the right one Link2
Matt Edwards
Sun Jul 04 2010, 02:42PM
I don't see why that cap would not work.
And, I wasn't suggesting that you purchase from mouser. I was just supplying you with a list of parts that seemed to work well for me. You could purchase any of those items at a wide variety of places.
When you get all of your parts, there is a decent pcb design floating around on the forums.
