  • Guests: 66
Bauerb2 (36)
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
Shorted NST as a ballast?
Xplorer
Mon Oct 25 2010, 05:39AM Print
Xplorer Registered Member #2416 Joined: Sun Oct 04 2009, 04:23AM
Sorry if this seems like a trivial question but, can a shorted NST (12kv 60mA) be used as a ballast for a larger transformer? I understand that NSTs have built in current limiting but it should still limit the current to 5 or 6 amps correct? They don't have GFIs. I just want to briefly test an old transformer that I have and I don't want to buy a MOT just for that. Thats all.
Thanks
-Tony
ScotchTapeLord
Mon Oct 25 2010, 05:49AM
Should work.
MOTs aren't that hard to come by... if you're dedicated.
You can ballast with anything from long coiled extension cords to a tub of salt water.
Carl Pugh
Mon Oct 25 2010, 04:46PM
Carl Pugh Registered Member #1064 Joined: Tue Oct 16 2007, 05:04PM
Put an incandescence light bulb in series with transformer primary.
Large transformer,high wattage light bulb.
Small transformer low wattage light bulb.
Works great, don't even have to use meter to determine if transformer is bad.
If use low wattage light bulb with large transformer, light bulb may glow. Don't be fooled into thinking transformer is bad.
monokel
Wed Oct 27 2010, 03:49PM
monokel Registered Member #2981 Joined: Thu Jul 08 2010, 01:47PM
Xplorer wrote ...
Of course, the primary coil of the NST must be shorted and the sec coil must be used like a ballast inductor (otherwise there would be a HV insolation problem).
But the sec coil of the NST has usually a thin wire and, further more, the inductance seen in the sec coil while shortening the prim coil is quiet big. It's so big that the high current of the large transformer cannot be used. The maximal current will be in the order of magnitude as the current for which the NST is rated. Thus there is no big difference if you use the NST as a transformer and leave the big transformer out (assuming that the sec voltage of the NST is roughly the same as the voltage of the big transformer).
Adam Munich
Wed Oct 27 2010, 07:56PM
Are you using it as a ballast for an MOT? If so you'll need quite a big NST to get 6 amps through. Why not use something like a 500W halogen lamp?
